Twisted Pear Releases ES Sabre 9028/9038 DAC Boards
  • pitdogg2pitdogg2 Posts: 8,296
    FTGV wrote: »
    Oh no, :# say it ain't so Rich. My DAC has been rendered obsolete. :'( The 9018 is a great chip but looks like the clever fella's at ESS have raised the bar. I look forward to your build and your impressions of the new DAC board and that new analog stage.
    Fred's in the house.
    Hello Fred
  • SCompRacerSCompRacer Posts: 6,612
    edited December 2017
    FTGV wrote: »
    Hey Fred!
    I wouldn't go throwing it away. ;)
    Yes, ESS has learned and applied improvements. Russ's Mercury I/V stage is also very impressive. The 9028 is higher current but will work with IVY/Legato output stages. The 9038 has four times the current so it needed a new output stage. The 9038 will be the up to 8 channel offering. Russ claims there isn't that much difference for the complexity you have to deal with. Again, chasing that additional few % or so. I want simpler now.
    Check out the Mercury thread in the TP forum at diyaudio. He hasn't released a schematic as of yet. I remarked how impressed I was with it. His response...
    "Believe me - this is by design - I have been working on this output stage for more than a year - and it started out discrete... Mercury is essentially Counterpoint but using OPA1632 where I have been using discrete components. It sounds as good as it does - because I was meticulous about designing and testing it... over and over and over.... "
    No common mode DC to worry about like with Legato discrete balanced out, barely detectable. I had lifted the ground on my Legato balanced out so I could get rid of the coupling caps and the flavor they bring along with having the corner frequency to figure/deal with. As you'd know, true balanced gear can work with the ground lifted.
    At one time he was reluctant to release the Counterpoint as folks would copy it. Now it's in the spirit of diy. Things change...lol I know one look and you'll have it figured out.
    Make yourself necessary to someone. Ralph Waldo Emerson
    Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ & Pro 11+ * Signature Series Sonore Music Server w/Deux PS* Twisted Pear Buffalo III Dual Mono ESS Sabre32 DAC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
  • FTGVFTGV Posts: 3,533
    Hello Fred
    Hello pdogg.
    SCompRacer wrote: »
    Yeah its not going anywhere. :) Even with the basic IVY analog stage it still oozes loads of musical goodness from the 1&0's it's fed from a Raspberry Pi music server.
    The new analog stage looks interesting. I will await impressions of you early adopters and at some point I may want to try one.
    Progress! Arduino DUE, Dimdim shield and 4.3 tft screen.
  • lightman1lightman1 Posts: 8,816
    Jeebus! You geeks should get a life. I'm looking at you, Rich.
    FTGV wrote: »
    SCompRacer wrote: »
    You too, Fred....
    lightman1 wrote: »
    lightman1 wrote: »
    FTGV wrote: »
    SCompRacer wrote: »
    You too, Fred....
    Says the super electron jockey
  • headrottheadrott Posts: 5,121
    SCompRacer wrote: »
    FTGV wrote: »
    Hey Fred!
    Rich, will the ESS9028 (or 9038) work with some SRPP I/V tube output analog stage(s)? I would like to upgrade my DAC board in my DAC and am definitely thinking of the ESS9028 (or 9038) board(s). Thanks Rich.
    lightman1 wrote: »
    I'm being worked to death, hardly any geek time at all! lol
    lightman1 wrote: »
    lightman1 wrote: »
    FTGV wrote: »
    SCompRacer wrote: »
    You too, Fred....
    Electons flow on the outside of the conductor and just below the insulating jacket...
    headrott wrote: »
    Good question! The 9038 puts out gobs of amperage compared to the 9018 and needs the new Mercury output stage. Folks are still waiting for more info in the thread at diyauido. The 9028 is higher amperage but compatible with the older IVY/Legato I/V stages. They have a basic page up for the newer DAC's but little specific info. You might ask and get better info in the TP 9028/9038 thread at diy.
    You ought to check out this fellow in China. They are using 9038 pro with tube output stage. Group buy at diyaudio for tube i/v.
    http://www.diyaudio.com/forums/group-buys/315474-pure-tube-es9038pro-9028-9018-akm.html
    The web site. IIRC new tube output DAC with remote like $2600. Loos like they sell parts too, like remote, LCD screen boards.
    http://quanghao.com/
    6moons had a look at it their DAC though I haven't read it.
    SCompRacer wrote: »
    headrott wrote: »
    Thanks Rich for the extremely helpful reply. I will check out the links you posted.
  • schwarcwschwarcw Posts: 7,130
    The display screen is nice! Color?
    Carl
    schwarcw wrote: »
    Yup. TFT screens are much nicer than LCD I've used. It's up to me if I want the touch to work. That means code. I hate writing code.....
    Is it your plan to display album cover art?
    Carl
    schwarcw wrote: »
    That would be complicated for me.
Howdy, Stranger!
