What is the best way to paint the grills on in wall RC85i speakers?
FZ1
What is the best way to paint the grills on in wall RC85i speakers? I going to paint them to match the wall color. A Crutchfield video said poke or stipple the grills with a brush but I want to be sure. Thanks
Answers
Hello,
It was always recommended to remove the scrim backing cloth and use an aerosol spray paint to avoid blocking the grille's holes. -
Thin the paint, use a stiff foam roller. light layers is key. As Ken states, the scrim should be removed no matter the application technique.
