RT16 Help
ultrasoudproductions
I recently purchased a set of RT16, a set of ls/fx in white, a PSW300 and a CS350 LS which I auditioned at low volumes before buying them. I got around to hooking them up today. I was very impressed with the ls/fx and a CS350 LS, but the unimpressed with the PSW300. I was delighted with the sound of the RT16 until I brought up the volume where I noticed that one was making a funny noise. I determined that the cone had separated from the foam surround. I did a little research and was wondering if anybody has done this repair by gluing them back and what glue should I use?
Provided the separation is only a portion of the circumference, that is an easy repair. As for the adhesive to use: that depends on what was used from factory, I.e., is the curred state hard, or still flexible? Using something that cures differently may cause a change in the response.
You could call customer service and ask. Otherwise Loctite 401,403,410 or 411
