This joint needs some more vintage hifi
14849505254
  • soundfreak1soundfreak1 Posts: 2,810
    Does that thing dim the lights in the room when you fire it up?
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • Viking64Viking64 Posts: 1,575
    The lights all go out completely and you just sit there in a blue glow. :p
  • Does that thing dim the lights in the room when you fire it up?
    I have another one just like it for the other 1.2tl. They don't dim the lights because they each have their own dedicated circuit
    Viking64 wrote: »
    I actually do that quite quite often.... like almost every day during the winter months :)
    I hope to do the same some day. :)
    edited November 2017
    I'd love to have a matched pair of 2500's. Nice sound.wouldn't want to lift them up though
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • I'd love to have a matched pair of 2500's. Nice sound.wouldn't want to lift them up though
    Yes moving them is a huge pita and the back to at 129lbs each. The thing that still impresses me is those 1.2s are able to soak up every single last watt to the clipping lights without the slightest sign of distress from those bridged 2500's.
  • Tony MTony M Posts: 4,067
    That's got to be one of the BIGGEST McIntosh Amps I've ever seen ! :o
    Congrats on owning 2 of them ! B)
    Most people just listen to music and watch movies . I am glad to be a part of a select group that tries to take our auditory and visual senses to a higher level: we EXPERIENCE them.... GOT SDA?... Got TFM ?
  • Thanks; I ran one 2500 for a couple years and I was very very happy pairing it with the 1.2s. But once I added the dreadnaught a while back I went on the hunt for a 2nd one. I can't see ever moving on from them as the newer big Mac monos are above my pay grade :'(
    Had to help my buddy (my tech) put one of those on his bench once......damn need blew a nut!
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • jdjohnjdjohn Posts: 249
    Thanksgiving holiday with my parents, and more receivers/amps coming my way from my dad's garage.
    Sony TA-1150 integrated amp...it's blowing fuses.
    Marantz SR6000 receiver...needs a lamp kit, but has a beautiful wooden cabinet
    Marantz 4270 receiver...this thing is a beast...some stencil worn off, and looks like a previous owner was a Dual fan :)
  • ConradiclesConradicles Posts: 5,525
    @jdjohn you selling any of these classic pieces?
  • txcoastal1txcoastal1 Posts: 8,879
    Damn bloodhound :p ;)
    2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures, Simaudio 780D DAC
    Gear on standby: Melody 101 tube pre, Modwright LS100, Unison Research Simply Italy Integrated
    Gone to new homes: (Matt Polk's)Threshold Stasis SA12e monoblocks, Pass XA30.5 amp, Usher MD2 speakers, Dynaudio C4 platinum speakers
    My dad always said "if you don't ask, you don't get" LOL
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    Open to offers...these are in various states of triage
  • pumpkinmanpumpkinman Posts: 5,596
    edited December 2017
    Maybe not a vintage as should it be for this thread but I'm happy to have snagged it
    Denon DP-47F
    Because I am The Pumpkinking
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • mhardy6647mhardy6647 Posts: 16,132
    Those are both very nice -- and Denon made some fine tts (not to mention cartridges!) -- but (personally) I am a little leery of those bionic arms. I like simple stuff...
    "Some amps run on self bias, some amps run on fixed bias. But his amps run on confirmation bias." -- seen on audioasylum
    The dp1200 is a very simple manual arm with only auto lift, no return or any servo features. Basically a manual TT but it does have auto lift at end of record.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    "The dp1200 is a very simple manual arm with only auto lift, no return or any servo features. Basically a manual TT but it does have auto lift at end of record."
    My Kenwood KD-770D operates the same way. Manual except for the auto lift at the end. (no return)
    There is a little story story behind DP-47F and why I bought it but I'll save that for another time. I certainly didn't need another TT
    Bill
  • delkaldelkal Posts: 89
    Auto lift at end of record us a nice feature. Its no fun waking up the next day and realizing your stylus was spinning around in the same groove all night.
    @soundfreak1
    I have a AT OC9/II that I plan to put on the Denon. You like the AT on your Denon ??
    Oh **** yes! Really stands out, excellent detail,clear separation between instruments and imaging. The impact of each note is remarkable. Mind you I use a good phono pre (Lehman black cube SE) and audioquest cable) but very very pleased with it!
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    delkal wrote: »
    On one of my musical therapy sessions years ago on that blue couch, I was playing the Carpenters Greatest hits or Christmas album and I fell asleep.
    My Technics SL1400MK2 has a inherent problem where all of the return mechanisms broke on every one ever made.
    So for about an hour or 2, it spun around like you said. :s
    The one and only time. ;)
    So from then on, Cd's were the go to physical median when I was really tired.
  • delkal wrote: »
    I once had a friend tell me that he passed out with his system at full volume and a CD player that had skipped for about 6 or 7 hours before he got up to do anything about it.
    I bet his speaker were well broken in after that ordeal.
    10 years of use in 6 or 7 hrs.
    Wonder they didn't burn up. :#
    Heathkit catalog, 1983.
    Then, as now, s-e-x sells.
    And she knows why she is in the picture too. ;)
    Only people like me smiles like that when we turn a dial and hear something amazing ! :p
    Nice rack. LOLOLOLOLOLOLOL
    there's one in every crowd...
Howdy, Stranger!
