What do use to stream music to your Hi-Fi ??
Just added the Pioneer Elite N50 to my family of Squeezebox Touches.Family Room HT 7.2/i]:Vizio Oled55h1 Pioneer Elite SC-LX502 Pioneer Elite BDP 85FD Eversolo DMP A6 Panamax M5300-EXSpeakers Fronts Fluance XF8L Center Polk Audio S35 Side Surrounds Optimus LS30's Rear Surrounds Optimus LS30's Subs SVS PB4000 x2 Living room 2ch: Crown Xli 1500 amp Teac EQ MKII FX Audio X6 Mk II DAC Squeezebox Touch Fluance Signature Tower Speakers Panamax M5100-EXOffice media room:Vizio M50Q6 50" Pioneer Elite VSX LX103 Squeezebox Touch Polkaudio R50 Towers Polkaudio CS 10 Panamax M4300 Monoprice 12" subMaster bedroom:Vizio M55Q7 Pioneer Elite VSX LX302 Pioneer Elite BDP 85FD Squeezebox Touch Polk audio RTi 6 fronts, Rears Dayton B652 Polk Audio CS10 center Monoprice 12" sub Panamax M5300-EX
I am currently using a dedicated PC, which is an Asus EEE Box, running JRiver on it's local HDD. I run Fidelizer on the PC to optimize it for audio. I have an external USB SSD that holds my music collection in a combination of FLAC and WAV which connects to the PC using an Audioquest Forest USB 3.0 A to Micro cable. I use a Netgear router, set up for LAN only (wireless and internet functions disabled), and use that to network the PC and my PS Audio PerfectWave MKII/Bridge II using CAT6 cables. This combo works real well as the PC doesn't require a lot of power and doesn't need to do much outside of streaming the audio from the SSD.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Inakustik Reference USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
Bluesound Node2 into Mytek Brooklyn DAC+ to Parasound P5.
Use Android devices for control using roon.
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
I just use my Roku or Xbox One to stream Spotify to my HiFi setup. Alternately all my physical media is on a computer running PLEX Server, which allows me access to it from anyway (including remotely via my iPhone/tablet, etc).
Depending on your budget and if you plan on storing data on it, finding a small NUC computer and installing it in your system may be the way to go. Then with a mouse and keyboard, you can both access Spotify & Tidal's web interfaces, but also the forum and any other thing you'd do on a PC"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
[/quote]
Check out the Auralic Aries Mini.[/quote]
I'm still sorting out my room stereos/configurations... but prematurely purchased BS Node2's... solid pieces of gear from what I read and all... but now buyer's remorse as I 'think' the Auralic Aries Mini' has the features I most want as I move forward with my system. The BS N2's will transmit 24/192 files...great for most, but I like the DSD capabilities of the Auralic... even though DSD represents a very small % of my music library.
I might just have 3 'never used' BlueSound Node2's (in black) for sale very soon...2.3TL's - Living Room
CRS+'s (4.1 TL's) - Office
SDA1C's - Famdamly Rm
SDA1C's - Master Bedroom -
I also use a dedicated laptop pc and it’s internal tb hard drive. Running JRiver software on the PC and controlling with the Creation5 iPhone app. The PC is connected to the my integrated amps usb DAC using Yamaha’s steinberg driver also installed on the PC. This enables up to DSD x2 or PCM x4 playback.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
recoveryone wrote: »Just added the Pioneer Elite N50 to my family of Squeezebox Touches.
Bluesound node 2
I bypass the internal dac and go straight to my Emm labs dacMagico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound -
mdaudioguy wrote: »recoveryone wrote: »Just added the Pioneer Elite N50 to my family of Squeezebox Touches.
The N50 act's as a DMR with the Squeezebox LMS, which means that you control it from the LMS (playlist etc...) I have nothing but good praise about the N50, I keep the 32 bit upsampling on always and everything I play through it sounds good. Check out my youtube sample, all of the music is from 192Kps to 320kps, even for a youtube clip you'll be hard press to pick out the 192kps sample.
Family Room HT 7.2/i]:Vizio Oled55h1 Pioneer Elite SC-LX502 Pioneer Elite BDP 85FD Eversolo DMP A6 Panamax M5300-EXSpeakers Fronts Fluance XF8L Center Polk Audio S35 Side Surrounds Optimus LS30's Rear Surrounds Optimus LS30's Subs SVS PB4000 x2 Living room 2ch: Crown Xli 1500 amp Teac EQ MKII FX Audio X6 Mk II DAC Squeezebox Touch Fluance Signature Tower Speakers Panamax M5100-EXOffice media room:Vizio M50Q6 50" Pioneer Elite VSX LX103 Squeezebox Touch Polkaudio R50 Towers Polkaudio CS 10 Panamax M4300 Monoprice 12" subMaster bedroom:Vizio M55Q7 Pioneer Elite VSX LX302 Pioneer Elite BDP 85FD Squeezebox Touch Polk audio RTi 6 fronts, Rears Dayton B652 Polk Audio CS10 center Monoprice 12" sub Panamax M5300-EX -
Nice. Where the heck did you find that cable for 39 bucks?I disabled signatures.
I read this and thought "Nice! Sounds like a perfect unit!"
Went to Google it and saw the $12k pricetag. Immediately closed browser window.Lumin S1. It is an all in one solution; file player, streamer, and DAC. Does Tidal, and now supports MQA. You can't get simpler than the S1, and it sounds great.
Find a used one since they are out of production. Don't get the bluesound unit as I don't know anyone who thought the sound quality was close to the AURALiC unit.
Permanently?
Correction....Audio Advisor has factory refreshed Aries Minis for 450.00. I am buying a second one.....now.
Upgraded from the mini to the Aries Femto, got a nice price on one brand new. They are selling them cheap due to the new G series coming out.
This Aries sounds so good, its unbelievable! It pairs wonderfully with my Cembalo River DAC, haven’t heard anything sound this good in my system.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
Audio Advisor has a demo Aries which was tempting....but I went with a second mini for secondary setup. You have to love a woman who buys off on this:
They have am new $499 -
afterburnt wrote: »
I like the internal design of this Yamaha NP-S2000 streamer:
Too bad no wireless though.
Hmmmmm, this might be an option. Ethernet to wireless adapter:
I can't get over the great design of the Yamaha. Even though it's dated and discontinued, I want it! -
Not a damn thing...
https://www.accessories4less.com/make-a-store/item/yamnps2000bl/yamaha-np-s2000-hi-fi-network-music-player-black/1.html
Yep, that's where I'd be purchasing it if I do go for it. Nice price.
The Yammy does internet radio streams as far as I can tell, and has a digital coax output.I'd still take the Aries Mini. The Mini does a few key things that Yamaha doesn't - like DSD, streaming, and digital out to use a separate DAC.
Yeah that sucks if it doesn't work with Tidal. I wonder if there's a way to get it working.I guess I should clarify that I meant Tidal, not streaming in general.
Honestly, I'm a 16/44.1 guy anyway, so that's not a huge concern.I bought mine 2014. It's been a great player. Only drawback is it only plays up to 96Khz.
Update: I still want to buy the Yamaha, even though it doesn't have wireless built in. I have issues.
I wonder how this strange looking thing is: https://www.musicdirect.com/network-player/bluesound-node-n100-network-music-player-ablsn100wht
Get s netgear orbi mesh setup your wireless extender will have ethernet and you can set it up by the yamaha. Problem solved and better wireless coverage in the house.Musical Fidelity Tri-Vista 300, Audioquest Thunderbird Zero Speaker Cable, Tyler Highland H2, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Lumin S1. While I don’t stream, yet, it does support Tidal, and some other high-res streaming source.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
If you can do ethernet, Sonore Ultra Rendu with LPS-1 power supply and DC-4 power cable. Substitute microRendu for Ultra to save $200, but I think it's worth the upcharge.Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Schiit Yggy * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
