Should I buy this Onkyo PR-SC886 for parts?
jimbo1421
in Electronics
Hello everyone,
I have an Onkyo PR-SC886 which I have liked very much. It has all the connectivity I need and the sound quality is fine. Balanced inputs/outputs are a definite plus. Last summer the HD tuner section went out and parts are no longer available. Recently, this model turned up on eBay here for under $200:
https://www.ebay.com/itm/Onkyo-PR-886-Home-Theater-AV-Preamp/332480578064?_trkparms=aid=111001&algo=REC.SEED&ao=1&asc=49453&meid=c43911bfc13043929f9d0c68867d5c83&pid=100675&rk=1&rkt=11&sd=332480578064&_trksid=p2481888.c100675.m4236&_trkparms=pageci%3Ad517d73c-de0d-11e7-bf5c-74dbd1809eea%7Cparentrq%3A4310d5601600abc2dbdf0778fff446d6%7Ciid%3A1
The seller says the tuner works well along with the other stereo channels, but has no idea about the HDMI connections.
Although I have online sources for the FM stations I like, I would be willing to spend the $200 for the parts & repair. And having a spare for other parts might be worth it. The only connection it does not have is HDMI 2, which I might like to have in the future when 4K content is more readily available. But there would be other work-arounds for that.
I think the issue is this: is it worth having another 8-10 year old Onkyo around for parts or is it just too old? Is it just too risky to buy off eBay? On the plus side, keeping the old Onker alive for another 5 years would definitely be worth it.
Any thoughts?
Jim
Any thoughts?
Jim
5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro
I am trying to tighten up my thinking about this.
Reasons to buy the Onkyo for parts:- I like the feature set of the PR-SC886 and some of the features I like are not available on other models, including balanced inputs and an HD tuner.
- $200 plus other moderate repair costs are reasonable to me.
- A new AV preamp is not an option at this time. I want to keep this one for another 5 years.
- I can easily make do with online FM stations streamed from my laptop.
- If I add a fan like this (https://www.acinfinity.com/component-fan-systems/aircom-s6-receiver-and-av-component-cooling-blower-system-rear-exhaust-12/) I might add several years to the life of my current PR-SC886.
- The history of the eBay unit is mostly unknown. It might have been poorly ventilated in the past, making the spare parts less usable.
- $200 could be put to other desired AV gear. My TV is dying, too.
- No HDMI 2 (no biggie since it will be a few years before there is enough content to make it worthwhile, and my current BDP dies).
- Both units are probably at least 7 years old. What is their life expectancy?
Any thoughts about how frugal people keep their gear going?
Jim
5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro - I like the feature set of the PR-SC886 and some of the features I like are not available on other models, including balanced inputs and an HD tuner.
Jim
Thanks for your comments. I have been almost exactly split between buying the scavenger preamp or not. So I have decided to stay put for now, get the fans the preamp and amp should have, and waiting for an attractive AV preamp to turn up. I am thinking the Parasound C1 or C2 might be right.
5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro -
Have you considered another option to just buy a separate AM/FM tuner? Should be able to find a very nice used one for half the price of the $200 expense of buying a broken preamp.
Actually, I think internet radio is where it's at now and I only listen to broadcast radio on my alarm clock in the morning. -
I have considered this, but one feature of the PR-SC886 is HD FM, which is near CD quality. I prefer locally generated programming with a real local DJ, and I have one such favorite public station, KUNM, which broadcasts in HD. It is quite good. Since they also stream online I am not missing them.
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro -
I'm a DIY'er that repairs stuff for fun and frugalness, IMO $200 might be a bit much as there is a working unit on eBay now for $224.99. Save your cash man and just stream the stations online. If you just have to go the tuner route, find a deal on an older used HD tuner.
https://www.ebay.com/itm/Sangean-HDT-1x-AM-FM-HD-digital-radio-tuner/222756114361?epid=1401612322&hash=item33dd4c8fb9:g:MtIAAOSwiBJaMtr~
https://www.ebay.com/itm/Insignia-NS-HDTUNE-AM-FM-HD-Radio-Tuner-with-Remote/263389848319?hash=item3d534222ff:g:I80AAOSwdnZaNEqs
https://www.amazon.com/Sangean-HDT-1-Component-Discontinued-Manufacturer/dp/B000J13TEE/ref=sr_1_5?s=electronics&ie=UTF8&qid=1513451434&sr=1-5&keywords=HD+Radio+Tuner
Then, when you are ready step up to deals on older model 4K. balanced, etc. pre/pro from Integra or Marantz in the $400-$600 range.
https://www.ebay.com/itm/Integra-DHC-60-5/222614358644?hash=item33d4d98a74:g:fncAAOSwKGhZkzk7
https://www.ebay.com/itm/Integra-DHC-60-5-THX-Ultra-HDMI-4K-Network-Processor-w-Middle-Atlantic-Shelf/132427429724?hash=item1ed54a375c:g:jNwAAOSwFSxZ~gKU
https://www.ebay.com/itm/Marantz-AV7701-4K-upscaling-Audio-Video-Preamp-Processor-Networking-AirPlay/292372640820?epid=175795337&hash=item4412c47434:g:YNsAAOSw3RZaNKQ8
https://www.ebay.com/itm/Marantz-AV7701-7-2-Channel-Pre-Amp-Processor-Amplifier-Theater-ORIGINAL-Remote/302555251217?epid=175795337&hash=item4671b2c211:g:yUMAAOSwaSZaJwlt
https://www.ebay.com/itm/Integra-DHC-80-6-11-2-Channel-Dolby-Atmos-Ready-Network-A-V-Preamp/172755059520?hash=item2839010340:g:N84AAOSwCkZZVUWI
then sell your unit as is....for $150-$200
2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Mirage Omni S8 sub1 | Mirage Omni S8 Sub2 -
Thanks, WLDock. The DHC-60.5 looks suitable.5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro -
That 60.5 is a Beast of a Pre/Pro for $450-$500. Mated with a stout amp, it just does not get better for the money. That unit had a $2000 list price.
http://filedepot.onkyousa.com/Files/sell_sheets/DHC_60_5_07-10-13-US-hqp.pdf
Great budget upgrade path vs. blowing half the budget repairing an old unit. Even if you sell your Onkyo for only $150.
Your Welcome!
WaltPost edited by WLDock on2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Mirage Omni S8 sub1 | Mirage Omni S8 Sub2
