DS7200 Subwoofer
I am replacing my Polk DS7200 amplifier/receiver with a new one which will have binding posts for speakers and rca output for a subwoofer. I'd like to keep using the subwoofer but the only input is the 25 pin DIN plug. I'd like to find out which pins are the input for the subwoofer ( I assume two of them are) and whether or not this is a good idea. The alternative is just getting another subwoofer. Any help would be appreciated.
Thanks,
Mike
  • tonybtonyb Posts: 29,207
    Get another subwoofer.
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
  • Thanks for the input, tonyb, that is what I will do.
Howdy, Stranger!
