Ultra focus 8000 cable replacement
jflail2jflail2 Posts: 2,702
Has anyone found a viable cable replacement option for the Polk Ultrafocus 8000s? I’ve got a pair I’ve been using at my desk for years, and I get an odd, staticky sound at times, which appears to be driven by the cable. Just opened up a brand new set for a work trip, and I’m getting the same thing with this brand new set.
I ask bc the stock cable has a bit off an odd shape on the headphone end, so I doubt just any cable will do. Any input would be greatly appreciated.
  • mrbironmrbiron Posts: 4,753
    I would bet my left nut that the odd, static sound comes from your cellphone being too close to the headphones and/or source.
    Zu Audio Omen MK-1B's, Peachtree Decco65, Bryston BDA-2, Cheap TT, PS Audio UPC200, PS Audio AC3's, Zu Mission SC's, HTPC, One, Bottlehead Reduction & Crack w/Speedball
    edited December 2017
    Double Post Edited.
    VVVV Now it makes the one below me seem out of place :p
    Sorry Vik.
    Post edited by mrbiron on
  • Viking64Viking64 Posts: 2,671
    ^^^^ Shouldn't the second post be for the right nut? :p
    Ooooo....double posts!
    Haven't had one of those in a while.
    My wife has laid claim to the "right" and i am not allowed to gamble with it without her consent.
  • jflail2jflail2 Posts: 2,702
    Odd. I get it from both a direct connection to my phone, and my headphone amp on my desk. Regardless of source, it’s the same.
    When i have my phone on my desk, i get buzzing/static in my speakers right before an incoming phonecall, a text, and/or email. If the phone is pulled over a foot away, it doesn't happen.
    I'll let the more scientific guys explain that one. I just know it happens.
  • ALL212ALL212 Posts: 755
    The bigger question asks where your left nut is before an incoming phone call, text or email and if that is moved does it make a difference?
    Just asking...
    Aaron
    Usually sleeping under my desk......slacker!
    I don't know what you mean by "moved"? That would imply that is moves on it's own and or someone moves it for me in which case, i should get on the cash grab train like rest of the country right now. ;)
  • EmlynEmlyn Posts: 2,062
    The cable is 3.5 mm on the device end and 2.5 mm on the headphone jack end. It is a stereo cable except it also has the ability for a third signal to control or mute volume. The cable is flat to reduce tangles but as observed the 2.5 mm connector is proprietary. I would recommend contacting Polk to see if they can provide a replacement. There are 3.5mm to 2.5mm generic cables with return audio control but the shape of the connector is likely to be a problem on the 2.5mm end. The 3.5mm end is standard.
    1. Polk LSiM707, 704C, 703; Dual SVS SB2000 subwoofers; Marantz SR7011 receiver; Parasound A23 amp; Oppo 205; Toshiba HD-DVD Player; Sony 65" 4K TV; FIOS; PS Audio Power Plant Premier; MIT S2 cables
    2. JM Labs Electra 920.1; Parasound JC2 Preamp; Sonic Frontiers Power 2 amp; Sony HAP-Z1ES; Oppo 105D; Music Hall MMF7 and Acoustech phono pre; PS Audio P1000; MIT S1 Cables
    3. Polk LSiM703; Pioneer Elite SC97 receiver; Oppo 203; Squeezebox Touch; MIT S3 cables
  • WLDockWLDock Posts: 2,128
    Polk should have them. I have the UF8000's, Buckle, and the Hinge headphones. I have ordered cables for the latter two from Polk.
    Call: 1.800.377.POLK (7655)
    FAMILY ROOM
    HDTV - Sharp AQUOS LC-70LE600U 70" | AVR/Streamer - Onkyo TX-NR3008 | Amp - Parasound HCA-1203A
    Blu-Ray/Media/Gaming - Sony PS3-320GB / Microsoft Xbox One | Broadcast - Xfinity X1 Platform
    Front Spkrs - Coming...DIY Statement II | Center Spkrs - Coming...DIY Statement II | Rear Spkrs - Artison Portrait LRS
    Sub - DIY Stereo Integrity HT 15 | Sub Amp - Dayton Audio SA1000
    Wire - Audioquest Type 4, BJC Belden 5000 | HDMI - BJC Belden | Power Cables - Pangea | Surge - Monster
    Thanks Emlyn. You're spot on with the odd shape/size for the can side, so I haven't found viable replacement as of yet.
    WLDock, these are actually fresh out of the box. Ordered a second pair a year or so ago on sale and tucked them away. Odd static/feedback right out of the box (including when my phone is several meters away from them and not connected), so I guess I'll just have to live with it.
    To follow up here a few months later, I was on the train to NYC last week and decided I didn't want to listen to music, nor the people around me, so I put these on without the cable connected and turned on the noise cancelling. Turns out it's something in the headphones themselves, and is related to noise cancelling, as I received that buzz/static/feedback with no cable connected whatsoever.
    I think I'm going with the Sony NC bluetooth headphones as replacements. While expensive, they apparently don't have any issues with NC buzzing, and the blue tooth sounds rather handy.
Howdy, Stranger!
