Vintage Monitor and SDA Speaker Deals
Unicorn.. oh my I'm LMAO
Ok if you do an xo rebuild and your rings Larry they are darn nice BUT NO nowhere near that price. You will lose money on the sale but still don't we all if we sell after upgrades... yes
If he did all of that to them they probably would be unicorns though...
Well then i have unicorns. I have a set of SDA1 signatures that have all sonicaps and mills with Larry's rings. -
I'll give you $4.73 and a lightly used cheese doodle for them.
Pffft... I have a used blow up doll named Shirley, half a bottle of Jim Beam Rye, two beef sticks and a Pink Floyd Dark Side of the Moon 8 track that I'll give him for them.
Top that...."Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
Mon 10's for less than a Benny in LA - no affiliation.
https://losangeles.craigslist.org/sfv/ele/d/polk-audio-3-way-speaker/6393732663.htmlVA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Too rich for my blood, but at least I know where my ex and bottle of Jim Beam got to... -
It's only 1 speaker.Most people just listen to music and watch movies. I EXPERIENCE them. -
UGH - need to look more carefully - good eye!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
What if I said I could secure you some black paint...?
Guy up in Denton north of FtWorth must be his cousin. Had a pair of SDA-1A without IC and no grills wanting $800 obo. Cabinets looked like they'd been tied behind the limo when he and his sister got married. Said the drivers were fine though and sounded like new.
The various offerings of vintage Polks out there leave you scratching your head. Either crackhead pricing (west coast comes to mind)....or someone's partaking said crack, asking big $$$ for a pile of excrement.Don't take experimental gene therapies from known eugenicists.
Pair of SDA 2 and another pair that needs identification for $400, down by the Jersey shore. Seller says he got them boxed and thought they were brand new (the SDAs I guess). He may have cable.
https://southjersey.craigslist.org/ele/d/polk-audio-speakers-4-total/6409845821.html
no affiliation -
no affiliation
Those look like a very early pair of Monitor 10's -
They are
There is 2sets of speakers.10's and 2's.Musical Fidelity Tri-Vista 300, Audioquest Thunderbird Zero Speaker Cable, Tyler Highland H2, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Either crackhead pricing or someone's partaking said crack
What's the difference between a crackhead and a partaker of crack?
afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
A crackhead will take $20 for a pristine set of SDA's, whereas someone smoking crack wants $2000 for an abused set.Don't take experimental gene therapies from known eugenicists.
The crack pipe was passed around the circle but he was not a partaker so he waved it away. He could have partook but declined to partake because if he'd partaken he'd be a crackhead.
Are there any speakers in this pic that you like @FestYboy?
Yes!!! The 2 bottom central pair are (appear to be) upper end Sony APM, especially the black pair (port configuration is different between the mid and upper end series).
Why do you ask? -
I'd be all about the APM AV-930s (black pair). The others are the little brothers to the 690s I have in my avatar.
http://pages.ebay.com/link/?nav=item.view&id=263324234413&alt=web
No affiliation, but seems like a reasonable price.
http://pages.ebay.com/link/?nav=item.view&id=132421905866&alt=web
Cheap??? Just far away. -
So is the auction for rt25's or srs?
Curious as I'm 30 minutes away.
One of each, maybe? -
That's one mucked up listing
SDA 2BTL, VPI Prime, Soundsmith Zephyr MKIII, Rogue Ares Magnum, McCormack DNA 0.5 Gold, ARC LS-17se, Cambridge cxn v2, MIT AVT MA ic’s and speaker cables, ps audio stellar power plant 3
From what I gather, it's the SRS since that's the items pictured. The description is a stock copy of Polks literature. -
To add further confusion, the positive binding post nuts are on the left but the sticker says they are supposed to be on the right.
The most important thing to find out is what type of interconnect socket it has. If it's pin blade then they are 1.2's and the binding post nuts are in the correct position regardless of what the sticker says because Polk is notorious for using old stock on newer models. If the socket is blade blade than they are first generation srs's and the positive binding post nuts should be swapped over to the right side.
If someone here on the Forum ends up buying them, remove the four screws on The Binding post cup to make sure everything is correct.SDA SRS 1.2TL's
SDA 1C's w/Clarity Cap ESA; PA, Mills, RD0194-1's
SDA 2B TL's w/RD0198-1's
Yaqin MC-30L integrated tube amp
Yaqin MS-20L integrated tube amp -
Price has been edited... Now states $999.00 opening bid. Hmmm
The cabinets don't look original to me. Home made or from a different speaker?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Not sure if these have been posted:
https://portland.craigslist.org/mlt/ele/d/polk-audio-sds-srs-23-speakers/6420522933.html2 Channel
Pre:Bryston BP173
Amp:Bryston 14B3
Speakers: Golden Ear Triton Reference
Source: Oppo UDP-205, Bryston BDA-3, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
Display: Sony XBR65Z9F
Pre: Anthem AVM90/JBL SDP-55
Amps: Parasound A31, A51x2
Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
Subwoofers: SVS SB16 x 4
Source: Oppo UDP-205, Apple TV, Amazon Fire
Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
Display: Sony XBR85Z9G
