MagniFi Mini - HDMI ARC - does power up when TV turned on
I have a MagniFi Mini connected to a Panasonic Viera TV via HDMI ARC
Everything is working except for the sound bar turning back on when I turn the TV on.
When I turn the TV off, the sound bar turns off. However when I turn the TV on, I have to then turn the sound bar on as well.
Is there a way to make this work?
Answers
  • bigendianbigendian Posts: 2
    I have the same question. Any response from Polk?
  • KennethSwaugerKennethSwauger Moderator Posts: 6,300
    Let me check with Polk's CS guys and I'll post it.
    "That which can be asserted without evidence, can be dismissed without evidence."
    — Christopher Hitchens
  • motorhead43026motorhead43026 Posts: 2,362
    edited June 2017
    I have the same issue. Not all the time, but most the time. Also same connection as the OP.
    2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk Signature S60's
    Cables: Wireworld Eclipse IC, Audio Art IC3; Speaker cable LA International SS-800; PS Audio AC-3 power cords; All into a PS Audio Dectet Power center.
    All TV's sound enhanced by Polk Magnfi Mini's.
    Other; SDA2BTL's, M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage.
    Memes are sign language of the ignorant, for the ignorant
    We use to lock up the mental cases to protect the children. Now we lock the children up to protect them from the mental cases.
    Hello,
    I'm working with Polk's CS department and they've asked me to find out if you are programming the remote or are you using HDMI-CEC/ARC? If so, what brand of TV do you have?
    Regards, Ken
  • To add to Ken's question, has the Mini been added to the network via the Google Home App for any firmware updates?
    FYI, I went ahead and purchased a MagniFi Mini and connected it via HDMI ARC port on my Sony NSX-32GT1. It has been working flawlessly. Turning my TV on and off via the remote also turns my MagniFi Mini on and off. My TV remote also controls the volume, so no universal remote nonsense to deal with.
    I'll add this is the only product I could find that both fit a 32" TV and had HDMI ARC. It looks great, integrates seamlessly with my TV, and sounds absolutely fantastic.
  • same problem here!!! ARC won't power on the magnifi mini... only power off!!!
    what is the solution for that?
    Has it been added to your network via Google Home App?
Howdy, Stranger!
