Polk Signature S60 -- too much treble?
I just picked up a S60/S20/S35/HTS-12 combo. I'm driving these speakers with an older Onkyo 626 AV receiver. They are setup in my living room (30ftx20ft) that has hardwood floor (no carpet).
Previously, I was using a pair of really old JBL P30 speakers with the same Onkyo amp. IMO, the S60 in comparison presents a phenomenally wider soundstage than these old speakers. The clarity of the various instruments/vocals was also much improved.
However I feel like the high frequency portion of the sound is a bit much. I tried using Audessey XT and played with a various options available in the receiver (direct-mode, dynamic eq, cross-over..), and still feel like there is too much emphasis on the highs with mids taking a back-seat (I wonder if this is a preference thing). I'm curious to see what other folks' experience has been with these speakers. I'd also appreciate any feedback you have on improving the sound. Thanks!
    Clipdat Posts: 12,559
    Are you unhappy with the high frequency reproduction during movies or during stereo music listening?
  • Nothing at all forward or harsh about the S60's tweets.
    Skip has it covered.
    2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
    Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
    The best way to predict the future is to invent it.
    It is imperative that we recognize that an opinion is not a fact.
    Imagine making politics your entire personality.
  • cfrizz
    cfrizz Posts: 13,415
    I have the S60s, and I find they have a terrific balance between the tweeter and drivers and sound great for music.
    I also have hardwood floors, but the difference is that I'm running my system with separates, including a 405wpc amp, so the speakers have all the power that they need no matter where the volume knob is.
    Listen to Skip, and start making changes.
  • @DSkip - Thank you for that insight. Can't do much about the space. I don't suppose throwing down a thick carpet is going help much (or will it?). I guess I'm more inclined to start with the weak amplifier and improve that. Unfortunately the Onkyo NR-626 doesn't have pre-outs, so have to trade up to a better model for that. Any suggestions for how to go about this route?
    @Clipdat - It's during stereo music listening.
    @motorhead43026 @cfrizz - Thank you for that data point. I'm more inclined now to try swapping out the amp with something with more power. I've gotta say both your amps are way more expensive that the combo speaker set that I purchased :smile:
  • Nightfall
    Nightfall Posts: 10,042
    edited December 2017
    Get a large area rug, center it in front of the speakers, keep the speakers directly on the floor. Any windows get some heavy drapes on them.
    The step above that is room treatments on the wall. Sometimes you can find those on Craigslist cheap.
    afterburnt wrote: »
    Village Idiot of Club Polk
    tonyb Posts: 32,902
    While that entry level receiver may be part of your problem, the cabling might also be contributing. What are you using for cables ?
    No offense meant, it's just that the better your speakers are, the more they will reveal the weak links in your system.
  • rpf65
    rpf65 Posts: 2,127
    May want to figure out a budget before these guys bankrupt you.
  • mrloren
    mrloren Posts: 2,454
    Yes listen to Skip.
    I use to have an Onkyo 626, it was not a bad AVR, not great either. It was not bright either.
    What speaker wire are you using? Monoprice 12AWG is bare min. If it's 16AWG RCA/Big Box store junk this could be part of the problem
    Not knowing the total of your setup here are a few things to look at.
    Speaker wire, Monoprice 12AWG is not bad but maybe invest a few bucks and get some of Doug's Furez http://douglasconnection.com/Raw-Speaker-Cable_c33.htm Very affordable and a big step up from the Monoprice stuff.
    Room reflections. no carpet on hardwood floors can cause some room gain in the upper end. Try a couple of throw rugs
    Your AVR is not the worlds greatest. Think about replacing it soon before the HDMI board fries out (common problem with Onkyo). Denon, Marantz or Yamaha are good AVR's. You can get a good one for less than $600 referb from A4L https://www.accessories4less.com/make-a-store/category/avreceiver/home-audio/receivers-amps/home-theater-receivers/1.html Or shop, look for deals. Amazon might still be selling the Denon AVR-X3300H for $599. Something with pre-outs is wise so you can spend more later adding an amp.
  • deronb1
    deronb1 Posts: 5,021
    Uh ohhhhhh.....
    tonyb Posts: 32,902
    All the things mentioned play a role to correcting your problem. Better receiver, throw rug, better quality cables, source....tackle them one at a time. You'll hear an improvement with each step you take.
  • audionewbie123
    audionewbie123 Posts: 9
    @tonyb @mloren - I used monoprice 12 awg speaker wire and the closed screw type banana plugs from monoprice. This was based on the following research https://thewirecutter.com/reviews/the-best-speaker-cable/
    https://thewirecutter.com/reviews/best-banana-plugs/
    @DSkip -
    look at Doug's Furez cables if you decide to splurge on some. They do well in this kind of scenario.
    - I don't understand. Are you saying these cables will help with my treble issues? Also, how much were you looking for your SC-63?
    I will add the rug and report if that helped. Thank you for the tips!
    Tony M Posts: 11,009
    Does the speakers menu set-up have the fronts set to small ?
    Is the subwoofer output set to yes ?
    I've had a receiver that would NOT let me have a sub set to yes and the fronts set to Large at the same time. Weirdest thing I've ever seen for flexibility set-ups.
    tonyb Posts: 32,902
    @DSkip -
    Imho....monoprice is at the lower rungs of the ladder when it comes to cables. The Furez from Douglasconnections would be miles better. There are other cheap alternatives too which are a few steps up which are Signal cable and Bluejeans cables. Signal cable may still offer a discount if you tell them your a member here.
    Yeah, usually the rule of thumb when trying to tweak your system or problem solve is to try the easiest and cheapest tips first. Everyones listening environment is different so what works for one may not work for another. Trial and error starting with the cheapest first.
  • mrloren
    Well at least you are using decent speaker wire. When I went from Monoprice to Doug's Furez I did notice a nice detailed difference. Thing about getting good cables is they are a one time buy.
    That AVR @DSkip has up for sale is a great deal. If you're not going ATMOS or DTS-X it will have enough power for your speakers.
    @tonyb is also correct, start with the lowest cost upgrades and see how it changes the sound.
  • My first thought is that your old setup may not have had crisp enough highs all along and now you are confronting a listening space issue you never realized you had. Surface reflectivity is a BIG deal on the high end as the sound waves have more than enough cycles to modulate together between you and whatever surface is reflecting. This is why rooms 'ring' at the higher end. I'm working on a job in DC with the same sort of issues on the higher end. Similar dimensions at 17x30ft, wood floor, flat spans of drywall walls and ceiling.
    Check the angle of the speakers, which can make an immense difference. If your new Polks have a wider high-end dispersion pattern from the tweeters than your older ones, they may need more angling. If they're angled inward and spaced as far to the sides as possible that helps and gives the most channel separation, but it isn't always practical or aesthetically pleasing to do that YMMV. Put a sound absorbent object or panel to the side of the speakers (in the listening space, not literally beside them). In our case, we're going to be using things like canvas paintings NO glass (seriously NO exposed glass in the listening environment if you care about your sound), cloth furniture, and tapestries on the taller vertical surfaces. If it's not a complete pain in the **** I'd do textured ceiling, consider it if you don't have that already but know it is nearly impossible to un-do if you go that way. Decorate... just no glass.
    Our space is built to accommodate small acoustic performer groups, dj's, and dancing. I tune spaces with my portable Casio grand. I've remodeled with all of the sound isolation in the walls, which absorbs most low frequencies that could have otherwise built up a strong drumming in such a long space, but the higher end has to be dealt with very differently. We even have round corners on all of our drywall to fan reflections. I am building in an exposed rough brick-faced fireplace on the longest flat surface as a sound break and the wall opposite the sound stage (litterally here) will also rough exposed brick, too. Getting that high end clear and crisp is an art, have fun with it.
  • cfrizz
    Nice post. Welcome to Club Polk JLStice!
  • sponger
    sponger Posts: 325
    Any chance that they need to burn in some more before the mids loosen up enough to balance things out? I know that it's a contentious issue for some as to whether such a thing as the so-called "break-in" period even exists. So, I am not making an empirical claim either way. Just thought I'd mention it since it doesn't appear it's been discussed based my quick overview of this thread.
    Denon X7200WA
    LSiM 705 703 704c
    Denon DP 400
    Yamaha CDC 775
  • Emlyn
    Emlyn Posts: 4,346
    cfrizz wrote: »
    Agree, excellent points. It’s like the ads for super high end speakers where the speakers are sitting in a vast room with bare walls, tile floor, and huge windows looking out to parkland. Looks nice but won’t sound good in that space. Of course, the speakers never have speaker cable running to them either.
    Got to match speakers to their environment to make them sound good.
    I have the similar Onkyo HT-RC360 and I've never really been happy or impressed with it for music listening. Although it does sound great during movies, no complaints there.
    One thing you could try is hooking your music source up to one of it's different inputs and then experimenting with all the settings. I know you mentioned you already tried the various Audessey settings. But I still think it wouldn't hurt to give it another try.
    Switch to an input you haven't previously used or configured and then play around with the various speaker settings, crossover frequencies, speaker size selections, and enabling the "Music Optimizer" option.
    mhardy6647 Posts: 32,926
    maybe I missed it -- but, perchance, are their any sort of tone controls on the OP's amplifier/receiver thingy?
    ... or am I just hopelessly stuck in the 20th Century?
    (PS I do realize that it's probably all auto-EQ computer smart calibrated-"I'm-sorry-Dave-I-can't-let-you-do-that" and all... but it still seemed worthy of mention (even if just for entertainment purposes, you know?).
    Actually -- if it's a TR-NX626 (??), it does indeed have tone controls, per the manual I found at https://www.onkyousa.com/Downloads/manuals.php
    Now, I have no idea if said controls are accessible from whatever mode the OP is using the thing in... but I still was pleased to see I am not 100% out of touch (only about 97%...).
  • sponger wrote: »
    I have noticed some positive change in sound characteristics during my 50 hrs of listening. It's possible there was some breaking-in effect, but hard to know for sure since, I have been changing speaker position, cross-over settings, audessey.
  • JLStice wrote: »
    I think you are right about my old setup. Never really had crisp highs.
    Didn't realize how important room surfaces are for quality sound reproduction. Thank you for your detailed response, very insightful.
  • Yep2 wrote: »
    In a last ditch effort, I used a mirror on my ceiling best I could to see both speakers, & installed a single acoustic drop ceiling panel there.
    That was the ticket!
    Trial & Error.
    Wow. One ceiling panel made all the difference. Interesting.
  • audionewbie123
    Clipdat wrote: »
    I will give that a try. Thank you.
  • mhardy6647 wrote: »
    I've tried playing with the 2 tone control settings on the receiver. It works, but not ideal.
  • rpf65
    rpf65 Posts: 2,127
    DSkip wrote: »
    The speakers will smooth out some over time but not enough to completely kill your current sound. Like we mentioned before, a rug might be all you need to suit your needs. It is probably your cheapest option and might just warm your room up from a design point as well.
    You thinking of opening up a rug department?
  • rooftop59
    rooftop59 Posts: 7,952
    One thing I will note is that a rug that will actually positively affect your space from a design perspective will most definitely NOT be your cheapest solution. In a room that large you will need at least an 8x10 rug to help, and a quality, good looking rug that size will cost you at least $200 bucks. At that price I would buy a new receiver first...
    Game Room 5.1.4:
    Bedroom 2.1
  • WLDock
    WLDock Posts: 3,073
    JLStice wrote: »
    ....If your new Polks have a wider high-end dispersion pattern from the tweeters than your older ones, they may need more angling. If they're angled inward and spaced as far to the sides as possible that helps and gives the most channel separation, but it isn't always practical or aesthetically pleasing to do that YMMV. Put a sound absorbent object or panel to the side of the speakers (in the listening space, not literally beside them). In our case, we're going to be using things like canvas paintings NO glass (seriously NO exposed glass in the listening environment if you care about your sound), cloth furniture, and tapestries on the taller vertical surfaces. If it's not a complete pain in the **** I'd do textured ceiling, consider it if you don't have that already but know it is nearly impossible to un-do if you go that way. Decorate... just no glass...
    You've hit the nail right smack on the head! Right off the bat the op audionewbie123 comment about the much wider soundstage pointed to the good and bad of the Signature speakers in his room.
    Maybe the OP knows this but maybe not. Just hanging paintings on the wall can alter the sound or dampening in a room. So, think of a room as a unique space that may need attention to produce the type of sound you are after.
    As far as receivers...the lower end Onkyo units sound different that the higher end units. I found the higher end units were more musical, powerful, and balanced overall ...on the top end as well. In comparison, the Pioneer Elite SC units were more lively and hot on the top end...and powerful! The Elite SC units are great for home theater and more subdued speakers...and those that want to ROCK the HELL out using an AVR. Only a dedicated amp setup will fair better that the SC units for banging out the tunes or movies. Getting a better receiver is always nice but might not totally fix your issue and may cost quite a bit more for better performance.
    Nevertheless, once you get used to the well adjusted sound of a good stereo / HT setup you will not want to go back to a lesser setup. Consider this example.... I previously had a very nice higher end Onkyo avr ($2099 list, 55lbs, four transformers) / Parasound amp (3 ch, high current) in my main TV room. I have rotated several different speakers over the years. Nevertheless, life happens and I had to sell the gear and now have a basic lower end setup in the room. I have an old cheap Sony AVR, Polk RT600 mains and CS400 center in the mix until I can fix an midline Onkyo unit I picked up for cheap. (I'm a tech that buys used stuff and fix it up as a hobby.) The point here is that my wife who is not into audio at all noticed the sound different and stated how hollow, tinny, and bright the system sounds now. She flat out said that I spoiled Her to good sound and clear dialog for TV and movies. This is the same women that gives me that look when I bring new speakers and gear into the house. I'm not making this story up!
    Nevertheless, I agree to try different speaker positioning, and a rug first. Then, if that does not do it maybe consider wall dampening and/or ceiling dampening.
    Here is a good read on understanding the effects of dispersion in a room: http://sanderssoundsystems.com/technical-white-papers/147-dispersion-white-paper
    There is tons of info around the net on these issues, dampening, etc. It all comes down to knowledge, trial and error. That's audio!
    2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Mirage Omni S8 sub1 | Mirage Omni S8 Sub2
