My Polk Lsi 705's needs an economy subwoofer
Trevorj800Trevorj800 Posts: 10
Not a lot of money, and I have to order them because I live in a place with no audio stores. What's a good sub in the $150--250 range? I am particularly looking for something that performs well at relatively low volume. It will be in a large rectangular room with 11 foot ceilings and lots reflections -- a glass door and bouncy concrete walls.
  • tonybtonyb Posts: 29,537
    edited December 2017
    so...you want a miracle then ? :)
    Big room, sub to hit lower than the 705's, for under 250 ? Maybe Dayton subs, but I won't commit to the quality of the sound as compared to others.
    Subs don't usually do well for low volumes.
    My guess is your problem is elsewhere in your system, those 705's can belt out some decent low end. What are you driving the 705's with ?
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
  • An Onkyo 626
  • F1nutF1nut Posts: 40,179
    There's your problem. Well, that and the room.
  • What's wrong with my amp?
    I've got CD/SACD players that weigh a lot more meaning your AVR doesn't have much of a power supply and it all starts with the power supply. AVR's are good for HT use, not 2 channel music.
  • EmlynEmlyn Posts: 2,103
    https://www.amazon.com/Bic-Acoustech-PL-200-II-Subwoofer/dp/B074131NKS/ref=pd_sbs_23_2?_encoding=UTF8&pd_rd_i=B074131NKS&pd_rd_r=SM0P8T7AG7XC78PPF91W&pd_rd_w=plFX6&pd_rd_wg=bAM1J&psc=1&refRID=SM0P8T7AG7XC78PPF91W
    There will be compromises in a budget subwoofer, but they can be minimized for $249. At $150 there isn't much worth looking at. Check out Amazon for other offerings like the Polk PSW505, Elac S10, Klipsch R-10SWi.
    A subwoofer and low volume tends to not make much sense. Why have a subwoofer at all if you're not going to crank it up and use it? The LSiM705s will not benefit from an added subwoofer at low listening levels.
    If you decide to upgrade to better gear later to better suit the large room, move the bargain subwoofer to an office or bedroom system.
    1. Polk LSiM707, 704C, 703; Dual SVS SB2000 subwoofers; Marantz SR7011 receiver; Parasound A23 amp; Oppo 205; Toshiba HD-DVD Player; Sony 65" 4K TV; FIOS; PS Audio Power Plant Premier; MIT S2 cables
    2. JM Labs Electra 920.1; Parasound JC2 Preamp; Sonic Frontiers Power 2 amp; Sony HAP-Z1ES; Oppo 105D; Music Hall MMF7 and Acoustech phono pre; PS Audio P1000; MIT S1 Cables
    3. Polk LSiM703; Pioneer Elite SC97 receiver; Oppo 203; Squeezebox Touch; MIT S3 cables
  • rooftop59rooftop59 Posts: 4,430
    Hey Trevor, do you have a full surround setup or are you just running two channel? If two channel, I would definitely look at selling the avr and adding the $250 to what you get from the avr. Get a used integrated or a used pre amp and amp (like a B&K reference 30) and you will be much better off.
    Or, shameless plug, my yamaha that I am selling is much heavier and much better sounding than that onkyo. http://forum.polkaudio.com/discussion/179720/yamaha-rx-a1010-and-parasound-hca-1000a#latest
    HT Rig:
    Denon AVR-X4200w; Parasound HCA-1205A; Arcam rDac; Mains: Dynaudio Emit 10 + MartinLogan Dynamo (original) sub; Center - Def Tech Procenter 1000; Heights, Center Surround - Klipsch KHC - 6 In-Ceiling; Surrounds - Monoprice in-ceiling; Sub - SVS PB10-ISD; Sony BDP-S390, FireTV gen 2
    Master Bedroom
    Marantz SR-5007; Audiosource Amp Two, PSB Imagine Mini, Boston VR-10 center, NHT Super One CI surrounds, ACI Titan subwoofer, FireTV, Arcam rDac; Bryson BPD-1
    Trev,
    Obviously your losing bass response at lower volume levels, which for the most part, is somewhat normal. A sub isn't going to help with that. More power will help some, and that receiver is pretty weak when it comes to power.
    Your choices as I see it, is....
    A- buy a better more powerful receiver. Make sure it has preouts to be able to add an amplifier down the road. Yours doesn't, which limits your abilities.
    B- if your system is just for music listening, move away from receivers and get a pre-amp/amplifier combo when the 'ol wallet allows.
    you can add a subwoofer if you want, but in your price range finding one that will dig deeper than your speakers is going to be tough. Especially if you have a large room. Bigger the room, bigger the sub needs to be to pressurize that room.
    As for what you have right now, some things you can check is....
    Are your speakers set to full range ?
    Are speaker levels set to 0 or slightly in the + side ?
    Is your receiver set to "no subwoofer" or none, if you don't have one now.
    Hope that helps ya out some, let us know how it goes.
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
  • mhardy6647mhardy6647 Posts: 18,711
    There are plenty of cheap (powered) subwoofers. I think that one gets what one pays for in that regard.
    Parts Express kind of runs the gamut vis-a-vis subwoofer options: from the ridiculous to the (relatively speaking) sublime, FWIW.
    https://www.parts-express.com/cat/powered-subwoofers/95
    FWIW, I have (had) a cheap powered subwoofer for a long time -- a 10" ported powered "Atlantic Technologies" brand buyout from Parts Express. It did its job, but was kind of one-note and not particularly 'musical' (for lack of a better term).
    Recently upgraded to something in another league entirely, though.
    "It's like watching a roomful of people who couldn't get through college algebra discussing the flaws of quantum physics theory. I guess it could be fun, but it's ultimately a waste of time." -- seen on audiokarma
    "Some amps run on self bias, some amps run on fixed bias. But his amps run on confirmation bias." -- seen on audioasylum
    "Writing about hifi is like dancing about architecture" -- paraphrasing some wag (possibly Frank Zappa)
    Concrete walls, glass, and high ceilings also make it hard to achieve good controlled low frequencies. It may take two subwoofers to get decent sound, and I would be thinking in the $500 a piece range for subwoofage. A new receiver alone may not do much to control the room reflections.
    Maybe Trev just wants a little more oomph when watching movies late at night at lower volumes.
    Still, imho....a big room, lower volumes, and a cheap sub = you just wasted your money.
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
  • I’m really interested in the new Monoprice Monolith subwoofers. I know, I shouldn’t be, but they appear to be awesome for the money.
  • VR3VR3 Posts: 22,197
    the 705, properly powered will deliver enough bass. Their bass would be better than any sub under 500 bucks new
    - Not Tom
    Vr3Mods.com ///// Version3Audio.com
    "No, that's silly talk. Dude, you can't possibly be this audio dumb so quit the act." - Doro
Howdy, Stranger!
