Does my setup work?
tkantamneni
A newbie here trying to setup audio in my living room. I had a new home and the builder gave me a 5.1 channel inceiling wiring and I am now working on installing the speakers. I want to leverage the current wiring and install the speakers on ceiling and not on the wall. Here is what I am thinking for my setup,
My room is roughly 25' length by 20' wide.
Option #1
225c-ls for Center
700ls for front L/R
80f/x-ls for surround
dsw pro 660 for sub
Option #2
225c-rt for center
70 rt for front L/R
80rt for surround
dsw pro 440 wi for sub
I am thinking of a 7.1 channel receiver with 100w output per channel.
My question is are these setups work well? are the individual parts compatible with each other? The option #1 and #2 is for price point and also not to make it too much for that sized room. Please advice.
Option #1
225c-ls for Center
700ls for front L/R
dsw pro 660 for sub
Option #2
225c-rt for center
70 rt for front L/R
80rt for surround
Answers
That’s a big room, so I would go with option 1. If you’re in the US, I would use the sub money for an SVS or HSU. Far superior for the money. And I understand wanting to use the in ceiling wiring, but I would highly suggest using a normal center channel if possible. Center and sub and by far the most important for ht.
Good luck and welcome to CP!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer
