What in the actual...>-(
obieone
On my main rig, I have an htpc, using windows 8.1. When I ripped y library to that, the bit rate was 1.4M. With this new PC on W10, the rip rate is 192k?
Am I missing something?
tia
tia
You can set the rip rate in medial player to flac, mp3, wav
What was the file format you ripped it to?
Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's. -
Yeah the default bit rate for WMP is 192k. You have to go in and pick a higher bit rate."Some people find it easier to be conceited rather than correct."
"Unwad those panties and have a good time man. We're all here to help each other, no matter how it might appear." DSkip -
Found the problem (I've never had to pick 'format' before)
