What in the actual...>-(
On my main rig, I have an htpc, using windows 8.1. When I ripped y library to that, the bit rate was 1.4M. With this new PC on W10, the rip rate is 192k?
Am I missing something?
tia
  • erniejade
    erniejade Posts: 6,315
    You can set the rip rate in medial player to flac, mp3, wav
    What was the file format you ripped it to?
  • ZLTFUL
    ZLTFUL Posts: 5,640
    Yeah the default bit rate for WMP is 192k. You have to go in and pick a higher bit rate.
  • obieone
    obieone Posts: 5,077
    Found the problem (I've never had to pick 'format' before)
