Q acoustics
deronb1deronb1 Posts: 4,295
Anyone heard or familiar with this brand?
  • deronb1deronb1 Posts: 4,295
    Ordered a pair of their older towers 2050i. Excellent reviews, but obviously never heard. Should be here Tuesday.
    Have these running for around 4 hrs. Nice all around speaker. Does some things better than others. Huge soundstage for their size. Very nice mids with a polite top end. Not a ton of bass, but electric bass is there and accurate. Soft mid kick, so i wouldnt call them punchy. Does jazz, acoustics very well, but more involved Rock leaves me wanting a bit more.
    Solid design and fairly heavy for their size. 6 ohm, but 92 db makes them easy to drive and fine at low volumes.
    Overall, so far, seems like a bargain at $400.00 brand new. I can see these excelling at HT duty as well.
  • Viking64Viking64 Posts: 3,240
    So Q designs speakers now? Do they shoot flames out of the ports if someone tries to play rap through them? :p
    Viking64 wrote: »
    They ARE of British design. Makes one wonder...
  • pitdogg2pitdogg2 Posts: 10,804
    Look good Deron don't sound bad on price. I have never heard of them
    Around 10 yr old company. Just getting started in the US from what ive read. The newer model is 700.00 pair.
  • halohalo Posts: 4,363
    I’ve heard of them. Never had ears on them but they were in contention for a new set of speakers after I move. I was looking into the 3020 bookshelf speakers. I know they were offering $100 off the towers putting them at $799 new. Where did you find them for $400? That seems like a heck of a bargain. Get an SVS sub to handle the deep bass and you’ll be in for a treat me thinks.
    halo wrote: »
    They are the 2050i towers. Predecessor to the 3050 towers. Similar specs. New model has reworked woofers and a slightly different tweet.
    After about 6 weeks, these have rounded out nicely. The lack of midbass energy was due to how tight the spiders were. Never seen a pair of speakers with drivers so tight. Really aired em out for about an hour with bass heavy tracks. Plenty of movement now, even at lower volumes.
    Really itching to compare these to the S55. Maybe if they come up on F&F sale.
    I've no doubt that these are fully broken in. Blend very well with the new sub at 60hz. Just a great all around speaker at a good price. Elusive, seductive tone at low volumes, which i listen to a lor. I hope someone takes a leap on the bookies at least and would love to hear other opinions.
  • stangman67stangman67 Posts: 782
    I have the 3020i bookies and 3090c downstairs in my living room 5.1 setup. Around 300 for the front 3, not bad at all. I liked the the signature s20/s35 combo better but that’s over double the cost. The build quality is real nice for such inexpensive new speakers and they look attractive to boot
    BlueSound Node 2 Streaming Tidal I Marantz SA8005 I Music Hall MMF7.3 I Lounge Audio LCR Mk III I Backert Labs Rhumba 1.1 I B&K Ref 200.2 I Focal Aria 926 I Wireworld Eclipse 7 IC's I Acoustic Zen Satori SC I Pangea AC14SE MkII/PS Audio AC-3 Power Cables
    Living Room HT
    Sony XBR65X930E I Marantz NR-1608 I Q Acoustics 2020i I Q Acoustics 3090c I FXI-A4's I DIY 15" Dayton SW
    stangman67 wrote: »
    Cool. I havent heard the 3000 series yet. The build quality is nice for sure. Ya, S20s are also 6 1/2" so om sure there is a bit more output. Im just digging the relaxed tone of the 2050i towers.
    I meant to say 2020i, same series as yours just the bigger bookies. I had to get the 3090 center because the earlier center wouldn’t fit height wise in the center spot. Either way, great cheap speakers all around
    Living Room HT
    stangman67 wrote: »
    I think so. Sound better than some more expensive speakers i had in here.
Howdy, Stranger!
