New Pass XP-22 Preamp
Pass has upgraded their XP-20 preamp to the XP-22. Aside from electronic upgrades, they replaced the umbilical cable connecting the power supply to the pre. The stock XP-20 cable was a flimsy, plastic POS. After getting my XP-20 I found out about the Revelation Audio Cyro-silver umbilical, bought one, and was amazed at the improvement. The XP-22 cable has good paper credentials; eleven pin aircraft grade connector/plug, and silver-copper wiring.
I guess I am going to upgrade and find out if there is good difference between each model.
http://www.moremusic.nl/pass_labs/xp22.html
http://www.moremusic.nl/pass_labs/Manuals/Manual-Pass-XP22.pdf
    nooshinjohn Posts: 25,034
    What kind of deal will you make me on the XP-20... :p
  • BlueFox
    BlueFox Posts: 15,251
    Right now my XP-22 price is based on the XP-20 trade-in. I hope I can throw in my RA cable, and get the difference down a little lower. It is hard to think something can be better than my XP-20 for only a ‘little’ more. :smile:
    The volume settings will be the first, and easiest, experience.
    I’m your huckleberry on the cable... let me know before you decide to do something with it. It should also work with my X1.
  • BlueFox
    If the X1 is a straight thru DB-25 then it will work.
    BlueFox wrote: »
    It is...
    Clipdat Posts: 12,557
    You officially have more money than God!
  • GlennDog
    GlennDog Posts: 3,084
    BlueFox wrote: »
    I use a Revelation ACryro in my Cary SLP-98 pre . . . I've not looked back!
    Highly recommended
    Source Lumin U1 Mini into Lampi Baltic 4
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • WagnerRC
    WagnerRC Posts: 2,138
    edited November 2017
    found it. Edit
