rtia 7 & csia 6 schematics
Would anyone happen to have the rtia 7 & csia 6 crossover & wiring schematic in pdf? I have been looking but, i just can't find them.
I looked here but??? http://forum.polkaudio.com/discussion/38755/polk-audio-speaker-wiring-schematics-more-all-models-except-sda#latest
Maybe I am looking in the wrong place? It would be much appreciated.
Denon AVR X4200W
Parasound A23 amplifier
LG 65" Ultra HD4k
LG 4kBR - UP970
Denon DVM 4800
Denon DP 3000 turntable
Saec 308sx tonearm w/
Dynavector 10x5 cart
Vincent PHO 701 Phono Preamp
MIT Avt3 Speaker c's
Audio Quest Big Sur ic's
Polk SDA 1C's modded
Polk LSim 707
Polk LSiM706c
Polk RTiA 3's
Polk 80F/X-RT
Polk DSW PRO 440wi sub
Infinity bu2 sub
"The early Klingon gets the Gagh"
    EndersShadow Posts: 17,517
    That list is the only one I know of. I'd call Polk CS to see if you can get a copy..... Thats gonna be the easiest way to get it.
  • Manticore
    Manticore Posts: 408
    Thanks Dan, I was hoping one of the members that modified their 7's & c6 had a copy hanging around. I will see if this post gets any more results. I was just entertaining the thought of upgrading the xovers. Future project.
    There is always room for improved sound... as I continuously read through past and present posts. :p Getting inspired!
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Infinity bu2 sub
    @F1nut upgraded his RTi A7's I think, but I'm betting he just looked at the existing ones and their values and then found better aftermarket ones to add in their place.
    but I could be wrong as Jesse is known to have shadowy connections to the underbelly of Polk HQ.
    F1nut Posts: 49,708
    Polk will not provide schematics for current production speakers.
    It's simple enough to find the values printed on the crossover components and follow the traces on the board.
  • Manticore
    Very good information. I was just looking to not have to take out the boards at this moment in space and time. When the itch becomes more prevalent (probably in the fall or early winter) i will pursue this further.
    I have enough to do around the house, yard, pool, dogs, grand kid, wife...I think that's almost everything?
    Thanks for the info guys. It is greatly appreciated!! :):)
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Infinity bu2 sub
  • gp4jesus
    gp4jesus Posts: 1,969
    edited November 2017
    I know I have a CSI A6 schematic. Hafta find my flash drive
    On the A7s:
    1. 86 the woofer's* LP filtering,
    2. re-wire them* w/12 ga or bigger
    3. re-wire the mids w/ 12 ga
    4. buy an EXO, set for 125hz
    5. PU another 1500* or a P'sound 1000** (or two**)
    6. upgrade the MT passive XO parts
    and revel in SQ improvement particularly bass response!
    ** one for each channel then find another use for the 1500
    My $.02
    Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work
  • Ooooohh Ahhhhhh :):):)
    I would be interested if your willing to share.
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Infinity bu2 sub
    F1nut Posts: 49,708
    All you have to do is remove the binding post plate, the crossover is attached to it.
  • gp4jesus
