Polk Audio SDA Speakers Non-Common Ground Amplifier Interface
    pitdogg2 Posts: 24,575
    Boy those do not show up often.
    F1nut Posts: 49,799
    I've got one....with the box B)
    Toolfan66 Posts: 16,906
    I had one with the box as well, but after the Dreadnaught mods I saw no reason in keeping it.. :#
    When will you ever see a new one again?
    F1nut Posts: 49,799
    Good question.
    edited November 2017
    For historical purposes right. lol
    So what are the TB 1 plug adaptors?
    Twin Blade adaptors, some 1C’s and 2B’s that can use the interface had Blade Blade sockets..
  • DarqueKnight
    I bought mine and keep mine for research purposes.
    Toolfan66 wrote: »
    You know I was leaning that way but dismissed it due to the stock/serial number factor.
    Thanks Larry
    Well yea how else would we of known how many sheets of aluminum foil to use. Thanks for your dedication Raife
  • motorstereo
    motorstereo Posts: 2,050
    I had one with the "baked potato mod" (thanks Jesse and Raife) and it got the job done........it was also an undeniable sound upgrade when it got replaced with a Dreadnaught.
    I really didn’t think this would make it through the night, I’m shocked it’s still there, I want it just because of its condition, but I have no use for it, and I really don’t want another piece of closet jewelry that cost $150. LOL!!
  • FestYboy
    FestYboy Posts: 3,861
    Yes you do....
  • vmaxer
    vmaxer Posts: 5,116
    I have the same as well. Never used it though.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    Did those come with the speakers you bought new or was it always an after market item?
    If I recall you had to purchase separately, as well as the spike kit, I believe you could order the bass brace for free though..
    Jesse am I correct!!
    F1nut Posts: 49,799
    The AI-1 was definitely an extra cost item. I always thought the spikes and bass brace came with the TL models, but I could be wrong.
  • stones89
    stones89 Posts: 229
    I think you are right. I believe my spikes and brace came with my 2.3tl's.
    Basis 2200 Signature, Vector 4, Transfiguration Proteus, Allnic H3000, Meridian 200/563, CJ ET5, McIntosh 501's, Thiel CS6, 3.6, Polk SDA SRS 2.3tl, MIT EVO, KS/Wywires PC's
    Viking64 Posts: 6,683
    Nope. You are correct. I have both spikes and bass braces in my 2.3TL accessory kit. Although, that may not be true of earlier models.
    I also recall my Polk dealer suggesting solutions for my blown tweeter issues that were caused by me powering mine with an 80-watt Yamaha home theater integrated. They suggested bi-amping, but they warned me that I would need this interface with a non-common ground amp. They told me it would be about $150.00, so maybe that eBay seller is trying to get exactly what he paid for it. :p
    That makes more sense..
  • westmassguy
    westmassguy Posts: 6,850
    I believe the "Bass Brace" was required due to tip-over, safety regulations coming into effect. It just happened to improve bass response as a side benefit, hence the name.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    Well I would bet if not for all the Dreadnaughts built this would have sold a long time ago, but still surprised it’s still there..
    F1nut Posts: 49,799
    It's still way better than the stock pin/blade cable and even better with the baked potato mod.
    gudnoyez Posts: 8,066
    ????? Baked Potato Mod please elaborate, I happen to have one of these its not in use because of a Dreadnaught.
    gudnoyez wrote: »
    You wrap the plastic case on the AI-1 with layers of foil like a bake potato..
    Toolfan66 wrote: »
    gudnoyez wrote: »
    What can one expect after wrapping it in tinfoil? How many layers? Are you guys taking me snipe hunting :D Have you tried it yourself?
  • motorstereo
    3 layers of foil seemed to be the magic number if memory serves correct. I never did a comparison with mine (with or without foil) I just left the foil in place and just like Jesse said it is an improvement over the basic interconnect cord
    gudnoyez wrote: »
    Toolfan66 wrote: »
    gudnoyez wrote: »
    IIRC DK was the one who did the research.
    So that snipe's been killed
    OK guys do you do three layers around the box only or do you wrap around where the cord and cord protectors go into the box also? If someone can find that link where DK covers this please post.
