Corrosion Resistant Grease for Speaker Wire
I have to hang the Atrium 8s on Deckzilla this weekend....what would all y'all recommend for the exposed copper wires and binding posts to **** corrosion....I have brake grease and several Vaseline type products. Go ahead and take your shots....then tell me what would work best....cheers!
  • FestYboy
    FestYboy Posts: 3,861
    edited November 2017
    Dielectric grease. The others can react to plastics.
    @nbrowser you beat me by seconds
    pitdogg2 Posts: 24,481
    Why are you not using gold plated bananas?
  • FestYboy
    Ivan, I've seen too many plated connectors rust from the inside because they aren't rated for outdoor use.
  • rooftop59
    rooftop59 Posts: 7,952
    I live in central Tx, humidity is pretty high here (though not like the Deep South or Florida) and I have lived in this house for 6 years with speakers under a small awning with bare wire running in. The only problem I have had is with the damn birds that want to build a nest on my speaker...wires haven’t been a problem.
    Game Room 5.1.4:
    Bedroom 2.1
    F1nut Posts: 49,711
    Goose grease
    FestYboy wrote: »
    Interesting. I know a set that has been in use for 6 yrs. in the elements that has not happened. Maybe because we used shrink tubing around the body and down the wire about 6 inches.
    Viking64 Posts: 6,646
    Ilsco De-Ox and black spray paint.
  • soundfreak1
    soundfreak1 Posts: 3,374
    Replace binging posts with "gold" ones and same with wire conections problem solved. Unless you live right on salt water no further steps needed.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    F1nut Posts: 49,711
    FestYboy wrote: »
    It's got nothing to do with being rated for outdoor use. It's got to do with being cheap a$$ connectors using the wrong base metal. Any half decent connector uses copper, brass or phosphorus bronze as the base metal, which do not rust.
  • headrott
    headrott Posts: 5,484
    Viking64 wrote: »
    .......black spray paint.
    Please, do not bring up this substance. This is a banned topic on the Polk forum, as far as I know...... :)
  • headrott
    nbrowser wrote: »
    I don't think the Permatex is "outer space approved" though. I would definately pay the $710.00 for the extra assurance and reliability. So, the space grease cost more than the speakers?! So what!! We don't want those cheap a$$ connectors rusting, after all. Besides, why spend money on better connectors, when you can brag to your friends that you have space lube on your connectors, that is protecting them for several times the price.
    txcoastal1 Posts: 13,124
    kevhed72 wrote: »
    Jeez at that price it better do wonders on my junk too :o
  • headrott
    Come Jesse, just 'cause you haven't had the pleasure.
  • FestYboy
    FestYboy wrote: »
    That too!
  • DaveHo
    DaveHo Posts: 3,471
    I always coat all the connections on my outdoor speakers with DeoxIt gold. No corrosion issues for me.
    billbillw Posts: 6,163
    I would tin the leads on the copper wire (aka tiny bit of solder). Helps from excessive fraying too.
    For rig details, see my profile. Nothing here anymore...
  • kevhed72
    kevhed72 Posts: 4,950
    I hit HD yesterday and of course it took forever to find all the necessary supplies to ensure the Atrium 8s dont fall on anyone's head. As you can see, they dwarf the Atrium 4s:
  • Willow
    Willow Posts: 10,862
    Interesting post. I took away my back yard speakers. All good except the one right next to the pool. The connectors were no longer brass. Look more like faded metal. I'll have to get some grease next spring to help protect that one and perhaps find a different location.
  • soundfreak1
    Chlorine gas from pool. Eats almost all metal eventually
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • Willow
    This was after 6 mths. We keep our pool at the lowest levels possible. It's very rare that I crank up the salt chlorinator up high. Unless after a party.
  • soundfreak1
    How" high" is a relative matter. Chlorine is chlorine virtually no levels are good for any metal. Think about what it's doing to the voice coils and any other metal baskets from your speakers excetera excetera excetera. The only thing you can really do at this point is to keep your speakers as far away from the pool surface as possible and be prepared to replace wire every season. Air flow isn't a bad idea to keep it from concentrating, a large fan in the pool area running 24/7 wouldn't hurt but it's like holding back the tide. Just accept the fact that you're going to have a higher maintenance than anyplace else in the house.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • kevhed72
    Interesting tie in here...when they were taking apart the old deck I noticed the old metal flashing was corroded. The house is only 14 years old....my guess is it was the bleach I used on the vinyl siding during the powerwashing process. Bleach works wonders down here in the pollen-belt, but is corrosive and Im told can jack up the soap pump in power washers overs time.
  • soundfreak1
    Yes you need to replace all rubber gromets, washers, etc in presure washers after every 2/3 uses or every 6 mo. or so. Also use only "buffered" chlorine not bleach! Also for exterior home cleaning an algaecide is also a good idea.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    kevhed72 wrote: »
    OH YES IT WILL
    It would eat everything in short order in my hand pump pressure sprayer I used in my old basement shower stall to combat molds and mildew. After a few months it would no longer hold pressure and the spray handle just fell apart.
    I had to get "aggressive chemical" sprayers.
    Post edited by pitdogg2 on
  • Willow
    I agree, next spring I'll be moving that one speaker away from the pool. It was right next to it this summer. Next year it will be a good 10 feet away.
  • soundfreak1
    Just so you'll know chlorine won't even kill mildew it only defoliate the flower on mildew plants it'll grow back and then you'll see the black again it never kills the root system you need to use a good algaecide that will actually kill the root of the mildew plant and then it will be destroyed completely this is something I used to do professionally in the Florida area it's a big business down here the chlorine is used just at the defoliant to give the impression that you've killed it immediately but in actuality the plant will just RE foliate within a few months and the mildew stays there until you actually kill it with an algaecide or appropriate Mildowside. Just saying!
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    That's interesting. I've never heard that. I always thought dilute bleach was a miracle cure. ie: it kills everything! I'll have to look into an algaecide because we have a problem on our back deck, front basement entry, and north side of the house. It is painted stucco.
  • kevhed72
    So here are some more pics as the project progressed. After a couple of months I will paint the treated wood in between the 2 layers of vinyl board. While it may seem overkill and not as clean as simply **** the mounts directly to the undside of the roof, the Atrium 8s come in at 10 lbs each. The binding posts and wire ends were covered with a good amount of dielectric grease. Enjoy and happy Thanksgiving
