Polk RTia5 and Onkyo AVR HTR-393
PixOtt
Hi All, sorry this post may be repeated. I have a Onkyo Receiver HTR-393 with 110 W at 6 ohms. I am planing to buy a pair of RTia5 from my colleague which is rated as 8ohms which I think is okey to work with my receiver. But regarding the point of power output, this Onkyo receiver can do its part? My room is only 20 feet X 30 feet. I am getting this pair at very cheap price, as my colleague is upgrading to B&W. Any answer and help is highly reply appreciated.
https://www.cnet.com/products/polk-audio-rtia5-speaker/specs/
Do you have a sub? They will work full range so long as u are careful with the volume knob, but they won’t sound their best. However, it would be much safer crossing them over at around 80hz to a sub...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
hi rooftop59; Yes I have a sub and also a center speaker. Thanks for your recommendation. will try crossing over to 80hz to the sub for LF.
