So just got a pair of 10b with original stands
And was wondering how I mount the speaker to the stand, common sense would tell me to run some screws through the 4 holes into the speaker. Buuuuut I really don't want to do that, and I read that you shouldn't put holes in the box when mounting them, so my question is, how then? I've searched, not in depth too much, but can't really find anything. Maybe I'm not wording it right, dunno.
  • codycatalist
    I believe they are just meant to sit on it. I wouldn't drill holes into anything, if you must try some Velcro. That might mess with the coupling though, not sure.
  • ken brydson
    ken brydson Posts: 8,649
    Something like blue tack would be fine if you don't want gravity to do its job.
    mhardy6647 Posts: 33,037
    The earlier Polkstands had four large-ish, grippy rubber-like pads near the four corners of the stand that did a pretty good job of hangin' on to the loudspeaker when it was placed on the stand.
    9606201717_d3fb6c6688_z.jpgearlypolkfamilyportrait by Mark Hardy, on Flickr
    The 10B may have had that taller stand? If so, I have no idea about those, sorry :(
  • delkal
    delkal Posts: 764
    edited November 2017
    I believe those are the proper stands. When I bought my 10Bs in 1988 I bought some cheaper aftermarket stands and they were higher. Used them for 30 years but I keep thinking I should cut them down
    Like others have said, I wouldn't screw anything down. When the original grippy pads wore out I found an assortment pack of clear silicone half "dots" with an adhesive back at Walmart. I put one on each corner of the stand and put the speaker on top. Nothing slides around and I am convincing myself they "isolate" the speaker so they have to sound better!
    Probably not............but they do work.
  • jimmylee123
    jimmylee123 Posts: 105
    Well the issue is, I am having my first child soon and this system is out in my office. I work from home and will be spending a lot of time with Edison in my office as I work. So I would really like these to be secure, I see four holes on each corner where they sit, I'll attach a pic. Which I read you're supposed to attach with 5/8" screws, I believe it was. And sooooome how these were magically supposed to be mounted without putting holes in the box. Makes no sense to me.
  • jimmylee123
    So here is the stand and you can obviously see the four mounting holes, but also remnants of a rubber pad, possibly, that used to be there.
  • pkquat
    pkquat Posts: 742
    There is some semi tacky black mat for the bottom of drawers or tool boxes. It is usually sold in a roll. I cut a pad and use it in my car to keep stuff from sliding off a smooth surface. It is very compressable and doesn't leave a residue or stick to things.
    You could tie strap them to the stand if original and kid resistant is the goal.
    The other option is to make your own simple short stand. The speakers would more or less be on the floor. The stand would just tip them up some. I have seen this done for similar sized speakers.
    pitdogg2 Posts: 24,559
    Those are metal. I thought original stands were wood?
  • delkal
    delkal Posts: 764
    I did too. Here is a dimension drawing I have of the original Polk 7 /10 stands (they are supposedly the same). It clearly shows a wood top.
    I don't remember where I found this (maybe here?) but anyway here it is.....
  • westmassguy
    westmassguy Posts: 6,850
    I have those same stands. Home Depot or the Hardware Store. Thin, soft rubber discs, self-adhesive. put one on each corner. They're hair thin, but keep the speaker from sliding off.
    Could also cut and attach a piece of 3/4" or 1" aluminum angle across the back of the plate. Speaker won't slide back.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • smglbrth
    smglbrth Posts: 1,460
    Those are the exact same stands I had with my 7C's when I had them. They were original Polk and were screwed to the bottom of the speaker. I even had the instructions of how to mount it, per Polk at that time...
    Yeah, those look like the later (and taller, if memory serves) Polk stands.
    msg Posts: 9,434
    Am I the only one wondering if it's too late to back out of the kid plan? It's the least invasive option.
    No screws/screw-ing involved that way.
    You know, for the speaker stands, that is.
  • dkfreebird
    dkfreebird Posts: 1,182
    There are instruction for those that @dorokusai posted in 2004 on how to mount them.
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    North Star Intenso Dac
    Auralic Aries Mini Streamer
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5 peerless,Monitor 4 peerless,Polk R200,McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino Rogue Magnum 66 pre
  • lightman1
    lightman1 Posts: 10,776
    dkfreebird wrote: »
    Hey Dennis. I see trees.
    lightman1 wrote: »
    dkfreebird wrote: »
    Well that beats pink polka dotted elephants now doesn't it :p
  • jimmylee123
    msg wrote: »
    4 weeks until D-day, too late to back out now.
  • jimmylee123
    I had a bunch of those sticky pads so I added them to the corners over the screw holes. They seem to be doing a better job, and it miiiiight actually even sound a little better. This will have to work for now, still clueless as to why add screw/bolt holes if you're not supposed to screw them down.
    smglbrth wrote: »
    dkfreebird wrote: »
    my work is done here
  • OleBoot
    OleBoot Posts: 2,107
  • delkal
    delkal Posts: 764
    How high are the top of the stands compared with the older ones? Like I mentioned I have an aftermarket pair and have been wondering for years if I should cut them down,
    delkal wrote: »
    ^^ Those are the original stand dimensions -- originally used with the 7 and the 10.
    The later stands were taller -- but I don't know any dimensions, sorry.
    see: http://forum.polkaudio.com/discussion/129525/polk-monitor-7c-speakers-w-stands-milwaukee
    (borrowed image, obviously)
  • jimmylee123
    delkal wrote: »
    8 3/4" from the floor to the highest side of the metal plate. The metal plate might be 1/16" or so.
  • FestYboy
    FestYboy Posts: 3,861
    Interesting, this is what I have from subsequent purchases:
    Note the 2 different heights...
  • TennMan
    TennMan Posts: 1,264
    FestYboy wrote: »
    If you are worried about the speakers sliding off just add a backstop to those stands like these have.
  • FestYboy
    Not worried... Just posted to show that there were several stand designs. The shorter set came with 10s, bought at the same time when new. Same with the taller set and 7s. Must have been a 2g design change?
    Continuous improvement was big in the halcyon days of consumer hifi :)
