Gold plated, removable bridging bars
Hello group. I purchased a set of RTi70 speakers, but I am missing a Gold plated, removable bridging bar on one of them. I have spent sometime but have come empty trying to find one. Can somebody tell me the actual Polk name or Polk part # and where to find one. I am OK if there is a generic replacement. I have temporarily solved the issue by putting a piece of speaker cable. I would think that speaker value is somewhat lowered by having the wire instead of the bridging bar or am I mistaken?
  • F1nutF1nut Posts: 39,298
    Replace them with HIGH quality speaker cable. Stock jumper plates leave a lot to be desired.
  • decaldecal Posts: 2,979
    edited October 2017
    Ditto what F1nut said.
    Mine come from AntiCables...............
    http://anticables.com/jumpers
  • ken brydsonken brydson Posts: 6,840
    Here's mine...
    HT/Main- Panny 50" G10 Plasma, Pioneer SC-1222k AVR, Panny DMP-BD60 BDP, Polk LS90 mains, CS350LS center, LS/fx side surrounds, LS50 surround backs, SVS 25-31PC+ sub, Harmony One
    Office Rig- Marantz 2252B, Denon 2910, Kenwood KD2070 TT, Polk RTA 12B's/ RTA8t
  • F1nut wrote: »
    Thanks for the input F1nut.
  • decal wrote: »
    Thanks for the input decal.
  • Here's mine...
    Thanks for the input ken brydson.
  • I was looking to make my own speaker cables.
    1. Design - Is there an optimum design? I was thinking having a banana plug at the receiver end, twisting together the speaker end to a 6 inch piece and crimping a spade to the twisted end and to the other remaining end of the 6 inch cable.
    2. Banana plug - Is there a mid grade banana plug you would recommend?
    3. SpadeIs - Is there a mid grade you would recommend?
    4. Speaker wireIs - Is there a mid speaker wire and gauge you would recommend?
    5. Is there a mid grade Jacket you would recommend?
    6. Length - Is there a length one should not exceed?
    7. Is there any other factors to consider?
  • Your plan sounds good. Just make sure the 6" will be enough. Most any good quality banana will work, but I'd suggest going with a banana plug made from copper. Same with the spades. To give you some info on jumpers, please take a look at our Bravo Bi-Wire jumpers. If you want to make your own and save a bit of $, we can put together a kit so you can DIY them. If you want, PM me. I'll be glad to help you with any questions. As a Club polk member, we give you a 10% discount too :)
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • txcoastal1txcoastal1 Posts: 9,243
    @ultrasoudproductions
    FYI helipilotdoug is a cool cat
    Hi Doug
    2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures, Simaudio 780D DAC
    Gear on standby: Melody 101 tube pre, Modwright LS100, Unison Research Simply Italy Integrated
    Gone to new homes: (Matt Polk's)Threshold Stasis SA12e monoblocks, Pass XA30.5 amp, Usher MD2 speakers, Dynaudio C4 platinum speakers
  • pitdogg2pitdogg2 Posts: 9,405
    txcoastal1 wrote: »
    Hi Doug
    The best
  • Jimbo18Jimbo18 Posts: 1,677
    @ultrasoudproductions I echo what the others have said about Doug. He helped me out very affordably with some great speaker wire that he customized to match my spring-type speaker connections.
    Modest HT - Pio Elite SC-63, RT800i, CS400i center, RT25i surrounds, Def Tech PF 15TL+, Belkin PF30, Samsung UBD-M7500.
    Bedroom - HK AVR 340, Monitor 5jr+ Series2, CS300 center, Furez 10/2, Roku Stick
  • Thanks for the kind words guys :)
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
  • dromundsdromunds Posts: 6,847
    Doug does great work. Hopefully I'm appending a photo of some jumpers Doug made for me from six inches of my speaker cables. Its advisable to use the same wire in your jumpers as your speaker cables. As F1Nut said, use high quality cable. Doug also reterminated my speaker cables shown in the photo with some really nice Furutech ends. Talk to Doug and he'll set you up however you choose to go.
    https://us.v-cdn.net/5021930/uploads/editor/xp/85pnqyfy8g75.jpg
  • lightman1lightman1 Posts: 9,265
    Doug is my LSAF morning coffee buddy.
    He's good people.
  • dromunds wrote: »
    Hey Don, would you mind if I use that photo on our website? Thanks :)
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    Doug, of course you may use that photo. Regards. -Don
  • tratlifftratliff Posts: 565
    I agree with the group. Doug and his cables are excellent. I have a complete system of them from XLR to RCA to Speaker.
    You can’t go wrong with his works or experience.
    Legacy Focus SE, McIntosh C50, McIntosh MC601's, VPI Prime w/SoundSmith Zephyr MIMC, Parasound Halo JC3, Marantz SA-14s1, Oppo BDP-105, Furman Elite 15PFi, Douglas Connection Alpha Interconnects, Douglas Connection Alpha Speaker Cables, Pangea Power Cables
    Theater
    Yamaha RX-Z9, Legacy Focus SE (same as 2 Channel system), Def Tech C/L/R 2500, Def Tech BP-2X, Def Tech Pro-Monitors, Vizio M-75
    Office
    Teac NP-H750, Parasound Ztuner, Audio Engine P4N, Grado SR80, Grado iGrado, Audio-Technica ATH-M50, PC running High Rez files
    Living Room
    Yamaha YSP-4100 digital sound projector, Sharp Aquos 60"
    Bed Room
    Yamaha YSP-5100 digital sound projector, Sharp Aquos 70"
  • dromunds wrote: »
    Thanks Don :)
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
Howdy, Stranger!
