Powered subwoofer pulsing sounds .PSW110
pwinston
My subwoofer has a pulsating sound, I have tryed everything including unplugged it from the amp and plugged it into a separate power source and it still has post a popping noise. I have cut all the power off in the house and ran one circuit at a time and it still has a popping noise.
The sub is only 3years old. It is a great sub with excellent base response until now.
Hello,
In all likelihood there's a problem with the bass amplifier. Do you live in the U.S.? -
KennethSwauger wrote: »Hello,
Yes I do !
Maybe you're listening to rap. Sometimes that'll cause an irritating pulsing sound.
Hello,
In that case telephone Polk at: 1-800-377-7655 select option 1 and have the serial number and exact date of purchase handy when you call. Polk will be able to work with you to solve the problem.
Cheers, Ken -
Thank you for for your help.
