Wireless vs. Coax & Ethernet cables
As I approach moving our TV room I need to start thinking about which will give the best video and sound quality for both DirectTV and internet access to radio.
If I go wireless there will be a router in the room directly below the new TV room.
Wired vs. wireless....what's better for PQ and SQ?
    EndersShadow Posts: 17,534
    Best IMHO is wired in general. Less signal dropout, faster speed. If you cant run wires through the wall, look at Powerline Ethernet extenders.
  • kevhed72
    kevhed72 Posts: 4,959
    This was my initial thought....since of course I completely finished the room below since getting rid of the dining room was never on the radar until now. I wonder is DTV has a wireless receiver
  • polrbehr
    polrbehr Posts: 2,826
    DirecTVs wireless receivers are supposed to be good, according to the installer who did mine last year. But a few on here said wired was the way to go, so we ran all new RG6 throughout the house.
    To take the case for wired a step further, my router is in the living room, as are all of my HT components (Oppo, PS4, Denon AVR, and Wii-U), and they are all connected with Ethernet even though the wifi signal is in the same room. I did not have to break open any walls to do this, however, so I wouldn't lose any sleep if I had to go wireless... but I'd get the best router I could afford anyway.
  • Msabot1
    Msabot1 Posts: 2,098
    RG6 Quad Shield for video...also compression fittings for terminations..I like LRC's...
  • mantis
    mantis Posts: 17,056
    Wireless sucks. It's a wonder it even works. I would not try to stream video wireless.
    Go hardwired always no matter what. If you can't get a wire somewhere I'm sure a local Installer can.
    Dan
  • mantis
    DSkip wrote: »
    For sound quality I'd stick with wireless as long as your devices can support it.
    Out of sheer curiosity why would you think wireless would sound better then hard wired? I'm puzzled.
    Dan
  • steveinaz
    steveinaz Posts: 19,522
    edited October 2017
    I have the DirecTV genie wireless system---out of necessity---and find the video quality to be just fine. The remote receivers are a bit slow, but once the HDTV is fired up, it seems fairly responsive.
    The new house only had 3 rooms wired RG6, so the genie allowed me a cheap/easy solution for TV on the patio, in the shop, etc. We have cathedral ceilings, and trying to run RG6 in the attic would have been a nightmare.
  • mrloren
    mrloren Posts: 2,454
    Skip has a good point,
    Me I like hard wire whenever I can. Powerline is good too for most cases. I have a couple in the kids room's and they almost get full speed of my internet connection.
  • rooftop59
    rooftop59 Posts: 7,981
    mantis wrote: »
    Lots of factors to consider here. But i have a google mesh WiFi system with three stations and 300 Mbps internet. All three stations are hard wired. One station is set up right by the HT. I stream 4K wireless to the 4K tv no problem, picture is amazing.
    Game Room 5.1.4:
    Bedroom 2.1
  • mdaudioguy
    mdaudioguy Posts: 5,165
    mantis wrote: »
    DirecTV's wireless Genie Minis work fine. I don't think you can tell a difference between them and the wired version.
