Help me choose a tubed integrated
So I have the GoldenEar Triton 2's. They are 91db efficiency and a powered bass section so I would think they are fairly easy to drive. I'm looking to move from my current setup to a tubed integrated amp.
My budget would be around $800-$1,000.
I would prefer to stay away from vintage units. Also would prefer something easily biased.
I am currently looking at something like a used PrimaLuna Prologue 2, or a Jolida 502crc.
Any input would be appreciated!
Thanks,
Paul
  • hochpt21
    hochpt21 Posts: 5,423
    On the radar...
    Primaluna Prologue 2
    Jolida 502crc
    Cayin A-88t
  • ZLTFUL
    ZLTFUL Posts: 5,640
  • hochpt21
    Thank you @ZLTFUL I have considered a hybrid and Vincent would definitely be at the top of my list, but I think I am looking for a full tubed integrated...and one with the tubes showing :)
  • Msabot1
    Msabot1 Posts: 2,098
    Not an integrated but I have a Primaluna Prologue II pre that I enjoy quite a bit..Very good build quality..P-P hand wiring is a feature they incorporate into all their products...can't go wrong with that brand..
  • hochpt21
    Yea, I have really had my eye on Primaluna for awhile now. Their lowest models seem to be on the used market for right around the top of my budget. The Jolida seem to be a little lower in price and I feel like they are a quality brand as well.
  • Check out Decware. You can find their stuff used sometimes for the price you are looking at. Real nice amps that are auto bias and US made.
    Polk S10, S8, S4
    Polk RT8
    Polk Monitor 7s
    Working on getting SDAs
  • Mikey081057
    Mikey081057 Posts: 7,127
    The Chinese ones are a good value and sound VG when you roll some nice tubes into them.
    Garage | Polk Monitor 5B's
  • Mikey081057
    Also think about how you are going to connect the subs in the Goldenears
  • hochpt21
    deucekazoo wrote: »
    I've heard good things about Decware, but I thought thier stuff was all fleawatt types for super efficient speakers. I'll check them out though, thanks.
  • hochpt21
    The Goldenears have a LFE input, but you don't have to use it. I have mine connected now with just the speakers cables and it sounds great.
  • hochpt21 wrote: »
    deucekazoo wrote: »
    They make some for less efficient speakers. Your speakers at 91 are not too bad.
    You might be interested in this one.
    http://www.decware.com/cgi-bin/yabb22/YaBB.pl?num=1506200373
    Polk S10, S8, S4
    Polk RT8
    Polk Monitor 7s
  • decal
    decal Posts: 3,205
    Up your budget a bit and get a used Rogue Audio Cronus Magnum.
  • marvda1
    marvda1 Posts: 4,871
    i have one of these. great sound and a price to dip your toes into the tube waters.
    http://www.ebay.com/itm/Silk-Audio-MC100SE-KT88-Tube-Amplifier-Factory-upgraded-Yaqin-MC100B-/322795353608
    Speaker Cables: Organic Audio Organic Reference 2
    Interconnects: Argento Organic Reference 2, Argento Organic 2
    Puritan PSM156
  • Thorton
    Thorton Posts: 1,324
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • halo
    halo Posts: 5,616
    I had the pleasure of auditioning a Jolida Fusion 801 paired with ELAC Debut F6 speakers and I was totally blown away by that combination in a less than ideal listening room with minimal room treatment.
  • Mikey081057
    marvda1 wrote: »
    I have one and upgraded all the tubes with Shuguang Treasures and a nice pair of Tesla 12ax7/ecc83 vintage NOS pre tubes. it is very sweet sounding and the KT88's punch pretty nice.
  • hochpt21
    marvda1 wrote: »
    marvda1 wrote: »
    Funny, I actually found this while searching about a week ago. Just wasn't sure about the reputation of the brand. I'll look more into this one as well.
  • kharp1
    kharp1 Posts: 3,453
    Have you ever considered going to seperates and starting with a nice tube pre? Find one with dual outs (many have them) and use one set for LFE thereby reducing power needed for the mids/highs. The tube pre will give you a good starting point for the "tube sound" allowing more time to build funds for a future amp. Just a thought thrown out there.
  • Faustin
    Faustin Posts: 1,149
    I have dealt with Silk Audio in the past and I believe other forum members have as well. The owner Ray is a great guy. When I was considering the MC100, he invited me to his place to audition the unit. Purchased it and used it for a year or so and then moved up the ladder to a Rogue Cronus Magnum II. Next step will probably be going to tube separates.
  • hochpt21
    kharp1 wrote: »
    I have considered that. Part of the issue is that I am needing to sell the Krell, as that was part of the deal of me getting the new speakers. :) The other part is that I am looking to put this gear in a smaller rack and don't think I'd have room for separates.
    One option that I would potentially have is just getting a tubed amp. My GCPH phono pre can be used as a preamp on its own and does a really nice job. I could hook that directly into the amp and be all set. The only problem there is that I would not have the option for any digital music, which although rare, I do use from time to time.
    Hence, what has lead me to an integrated.
    tonyb Posts: 32,906
    How is an integrated going to solve your digital needs ? You need a dac, most integrateds don't have one.
  • mikeyb128
    mikeyb128 Posts: 2,885
    Keep the krell and buy a tube pre. I think sound quality wise, would be better than a 800 integrated. If it were me I would go this route. Or be more patient and save a little longer. There are some really nice Cary integrateds going for under 2000 with upgraded tubes in them, heck I've seen some in the 1500$ range that originally retailed for 5-6000 bucks. I love Cary and feel that one of their tubed integrated amps would outperform brands mentioned above. Not to mention they look as good as they sound. This is somewhat of a biased opinion though.
    2 channel:
    Theater:
  • ZLTFUL
    ZLTFUL Posts: 5,640
    edited October 2017
  • hochpt21
    tonyb wrote: »
    It is rare that I listen to digital and if then it is never critical. I just hook my computer streaming Spotify through a little HRT Music Streamer dac.
  • hochpt21
    mikeyb128 wrote: »
    I agree with you. I just have to figure out how to try to fit everything into the space I'm moving it to.
  • hochpt21
    edited October 2017
    This is how I had my gear at one point. Then we rearranged the living room. Now we are arranging it back and I need to fit it all in there again.
  • kharp1
    kharp1 Posts: 3,453
    Aw, man, that's easy...I thought you had some kind of serious space issue.
  • nspindel
    nspindel Posts: 5,343
    Funny that you're selling the Krell amp to buy the tubed integrated, Paul. I did the same thing. I got a VPI 299D. Over your budget, but don't let that stop you. Mine replaced the Krell, my tubed pre, phono stage, and headphone amp, not to mention all the cables to hook all that up. Haven't looked back once. Go for it.
  • nspindel
    Bingo.
  • nspindel
    Your rack gets cheaper too!
