Receiver recommendations for Monitor series speakers?
mrhoont
in Electronics
Hi all,
New to the forum.
My current monitor speaker setup is:
Polk Audio Monitor Series CS2 Center Channel Speaker
2xPolk Audio Monitor 60 2-Way Floorstanding Speaker
2x Polk Audio Monitor 40 2-Way Bookshelf Speaker
Polk Audio PSW125 12-Inch Powered Subwoofer
My Onkyo TX-NR656 7.2 Channel Network A/V Receiver is on its last leg (early stages of HDMI failure) and I'm looking for recommendations for a new unit. Prefer to move away from Onkyo (possibly toward a Denon). Thoughts?
New to the forum.
Budget?
Amazon has new Denon for cheap as they are clearing out older stock for the 2018 models
https://www.amazon.com/gp/product/B01KZRPNIQ/ref=s9u_simh_gw_i5?ie=UTF8&fpl=fresh&pd_rd_i=B01KZRPNIQ&pd_rd_r=BWZ69H6VJ12GQ9QN7FV1&pd_rd_w=7VAgG&pd_rd_wg=s8569&pf_rd_m=ATVPDKIKX0DER&pf_rd_s=&pf_rd_r=DQ6CJA9ETM29J0S8CZPM&pf_rd_t=36701&pf_rd_p=1cf9d009-399c-49e1-901a-7b8786e59436&pf_rd_i=desktop
or
https://www.amazon.com/dp/B01HL8KYAY?psc=1&smid=A3PO6K6MJQ13RE
or you can pick from A4L for refurb even cheaper https://www.accessories4less.com/
Yamaha RX-AXXXX , Denon AVR-X***** or Marantz
Your sub is decent but if budget permits any HSU or SVS sub will be much better.When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Working Warehouse; Yamaha A-S301, Sony DVP-NS3100ES for disc Plok TSX550T SVS PB2000 Mini tower PC with 400GB of music -
Thank you! These units are definitely within budget. Leaning towards the AVR-X3300W.
For the same price, the x4200w seems like a no-brainer...any reason not to go with this over the x3300W?
https://www.accessories4less.com/make-a-store/item/denavrx4200w/denon-avr-x4200w-7.2-ch-x-125-watts-networking-a/v-receiver/1.html -
no not really, If it was my choice I think I would get the refurb X4200W over the new X3300. Only upside to the X3300 is it is a newer model so it will receive firmware upgrades longer.
I would also look at the A4L X3300 and see if you can toss in an SVS or HSU sub to your budget. http://hsuresearch.com/products/vtf-2mk5.htmlWhen I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
