Help me choose a projection screen
hochpt21
hochpt21 Posts: 5,423
edited September 2017 in Music & Movies
I currently have a motorized drop-down 100" FAVI screen. Long story short it got damaged and it's time for a new one.
I think I want to go up to a 120". 16x9 format.
I have found basically the same one I have in a pull-down format for around $200. My main concern, however, is at that size (120") it seems the screens are more prone to wrinkles or edge-bend. I was thinking possibly a fixed-frame screen would be better?
Budget is $250 max and preferably under $200. I know that limits my options quite a bit, but I would like to get everyone's input.
Fixed, pull-down, drop down does not matter to me. I think I want a low-ish gain similar to what I have (I think currently 1:1)
Current projector is a BenQ HD w1070
Anyways, let me know what you all think!!
Thanks,
Paul
    pitdogg2 Posts: 24,579
    Have you thought about painted? No edge wrinkles. I have a friend who used a paint and it looks darn good.
  • hochpt21
    I hadn't thought about that, but where I have my screen it is partially covering a blacked out window, so that wouldn't work.
    It was a thought
  • hochpt21
    It was a thought
    And probably a much cheaper thought at that :)
  • PSOVLSK
    PSOVLSK Posts: 5,059
    http://www.carlofet.com/build-your-own-projector-screen
    I built my own with pretty good results several years ago. Mine wasn't nearly as nice as the one I linked, but as I said, it worked well.
    It should be noted that if I can build one, anybody can. I'm not what anyone would describe as handy. Handsy, maybe, but not handy.
  • hochpt21
    PSOVLSK wrote: »
    Thank you, sir. I'll check it out.
  • scubalab
    scubalab Posts: 3,101
    Paul,
    I have the 92" version of this screen and have absolutely no complaints. It is very well made, easy to assemble and install, and looks like it should have cost a lot more. Only downside is it's at the limit of your budget...
    https://www.amazon.com/dp/B00CYLOTPK/ref=twister_dp_update?_encoding=UTF8&psc=1
    When I was looking it was between Elite Screens and Silver Ticket. They both were darn near identical when I bought, and the price was almost exactly the same. IIRC, the reason I went for Elite Screens was because Silver Ticket were back ordered. So, here's another option that will be closer to the $200 'wish' budget:
    https://www.amazon.com/Elite-Screens-StarFrame-120-inch-Projector/dp/B01B53Q8M4/ref=sr_1_12?s=electronics&ie=UTF8&qid=1506456638&sr=1-12&keywords=120+fixed+frame+16:9
    I can't vouch for the Elite Screens version though, but reviews are very favorable for both.
    -Al
  • hochpt21
    @scubalab I looked at a few options on Amazon. Also looked at the DIY that @PSOVLSK recommended. Looked at the DIY quite a bit. Thank you both for the input.
    I love DIY projects and they are very rewarding, but right now with work and life, I ultimately decided to go with a kit route. Since I don't NEED a drop down screen, I feel like the quality vs value was with the wrap around tension kit, so I clicked BUY on the Elite 120" Fixed Frame.
    Very much looking forward to the extra 20 inches.
  • PSOVLSK
    Too lazy to look at the model I had, but I was very pleased with the Elite screen that replaced my DIY. I suspect you will be happy with your purchase. Congrats!
  • Dennis Gardner
    I built a 92x69 4:3 for my first pj around 15 years ago and still use the original blackout cloth on my 16:9 87x50 basically a 100 inch diagonal that I might have $50 total in the 2x4 frame hung permanently on my theater room wall. It is a 1:1 gain factor and serves me well. Here is a vendor that a 120 inch screen could easily be done without seams.
    http://www.ebay.com/itm/Carls-Blackout-Cloth-DIY-Projector-Screen-Raw-Material-Fabric-66x110-inch-Ma-/202045249357?epid=710128596&hash=item2f0ad5d74d:g:AJYAAOSwK31ZrDXf
  • hochpt21
    Truly sorry I forgot to update this thread...
    Ended up with a 120" fixed frame screen from Elite.
    Couldn't be happier!
  • hochpt21
    edited December 2017
