WTB Vandersteen 2C Sound Anchor stands from 1980s
geppy1
Hi, Looking for a pair of Vandersteen Sound Anchor stands for 2C speakers from mid to late 80s Thanks
Don't have any to sell but can say they're worth hunting for sure. I think they helped in every way.
weird, my stands look like that full of sand without the riser pegs.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Those were the originals. Helped with the top-over tests. Pictured are the second style to get the mid/highs higher up and get even more weight at floor to be harder to knock over. -
The earlier 2C and CI speakers are shorter by 3 inches then the later ones hence the taller stand
I'd contact sound anchor and see if they could build you a set. They build to order so it should still be in the cards.
Wouldn't surprise me if they had a pair in-stock ready to ship. -
I ended up with some PSB Gold i speakers AGAIN
