Surround with vintage Polks
[Deleted User]
in Speakers
I realize this topic has probably been beaten to death, but my topic may be a little unique. My system uses a pair of older Polk SDA monitors up front and I have been attempting to timbre match my surrounds. I was able after a long period of searching to locate a pair of AB700's from Polk. These have the same drivers as the older SDA's. I think I would like to replace my rear surrounds with similar AB models but I am less than optimistic about my prospects. Is there an equivalent model that isn't as difficult to find?
Hmmmm. Must be in the wrong forum!
Not seeing how SDAs and ABs are the same drivers... But if you want to match the SDA sound for the rears, look for monitor 4s or 5s or 5JRs. Obviously none of those mount into the wall like the ABs.
The ab700 s have the same midranges as my SRS 1.2's but the tweeters are SL1000's. Difficult to find. Ideally I'd like to get another set of these or AB800's. Barring that, something that sounds similar and mounts in the wall would be cool.
Are you talking about the SDA SRTs? Because standard SDAs run 65xx series drivers, ABs do not. IIRC they are a 7000 series driver.
Maybe a picture of what you currently have would dispel the confusion. -
Really Skip? All the pics I've found of the ABs have different baskets than the monitor series...
Please educate me. -
"Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
Please educate me.
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
Ok that's different then the pics I swap from a Google search. That explains quite a bit. -
You can also use a Monitor 5jr or Monitor 4.6.
I use 3 pairs of 4.6s, and 1 pair 5jrs in as bi-poles.Home Theater/2 Channel:
dhsspeakerservice.com/ -
^ that's what I suggested too (3rd post)
Great minds think alike? @westmassguy -
Well today I got an education on AB series speakers... Turns out the owner of a fastsigns that I contract with was one of the designers of the AB series speakers... And he had a pair installed in the shop that I was able to get a close look at.
so??? whadja learn???Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
So sorry, folks. I was out of touch a few days. THAT IS A PICTURE OF MY SPEAKERS! Well done. I need a couple more like that.
what I'm hoping to do is either find AB700's, 800's or 900's. Barring that, I'm looking for recommendations for similar sounding rear surrounds.
Well, if I understand correctly, there are 2 generations of AB series speakers... The early ones having the 65xx MWs with SL2k tweets, and the later having the poly-mica cones and tweets from the S series, and there being 2 different bezel plates to accommodate.
Also I learned that there was an SDA varient that never made production at the behest of Mr Polk himself.
I find it odd that Polk hasn't kept up with the very thing that put it on the map so to speak (SDA technology). -
Take a look at the RTA line, specifically the 8t or 11t. They also use the same drivers, but they are floor standers. I found that this type of speaker sounds amazing in the surround role.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
the end goal is to have timbre matched speakers that fit in the wall. I have an old set of SDA-1's which I also purchased in the mid 80's. They would be great as surround speakers but are too friggin huge. Spousal disapproval, bigly. I really need to go in wall with the rear surrounds.
Maybe for the rear surrounds I get a third set of MC60's to match my four Atmos speakers? Thoughts? -
I just came across some ABs (single MW) in my area for what I would consider cheap $10 x 4, if you're still looking for some. I'd be happy to grab them for you and ship them out. I'm waiting for verification that they are still available, and if they are, I'll pull the trigger and wait for your reply.
I have an extra pair of AB 700..The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Gentlemen! You are awesome! If you can tell me what the AB models are I may be interested. Otherwise I would love to make a deal for Nooshins AB700's.
I'm game for some if he's not.
I have a pair of AB700's in the den ceiling. Originally ('95ish) used as surrounds with DefTech BP-2000 fronts. Sounded very good. Currently used as rears with SRS1's as fronts and the BP2000's as surrounds/subs. Sounds great to me, but you can tell I'm of the opinion the timbre matching outside of the front three is not critical.Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Schiit Yggy * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
They should be 700s as well, I'll find out today for sure.
Picked them up, they have MW6512 drivers.
I'm in Lititz PA, so I can ship, or if you're close...
I am in Minnesota. Shipping would be best
Any good way I can pay you and the shipping?
Yessir, I'll pm you my PayPal. How many unit do you want? I'll likely ship USPS in the prepay boxes after I clean them up a bit.
Gonna pull one of the MWs apart: possible shifted magnet. Will test first and update. Should have results Monday evening at the earliest but no later than Friday. Working nights for this week.
