Motorcyle sound system advice.
projectbagger
Im currently in the middle of a bike build. I love Polk speakers and am going to be running them on my bike, however I need help picking out an amp to run everything.
I will be running 4 speakers on my front fairing and 2 speakers on my saddle bags.
the 4 speakers on my fairing are 6.5inch Polk MM6501
the 2 speakers on my saddle bags are 6x9 Polk MM691
my issue is trying to find an amp. all of the speakers are 2.7 ohm
I am looking to build a crazy loud system.
I am also looking for a small in size amp as I plan to install it in my front fairing.
can anyone give me a recommendation on what amp would be best for my setup.
Hey Projectbagger,
On my 2014 Streetglide I'm wanting to add the DB652 in fairing DB692 in saddlebags.
Any advice on what amp I can install in the front fairing?
This is what I'm toying with for my 2016 SGS . . .any experience with JM products?
http://www.jmcorp.com/SeeProducts.asp?PF=49AC Regenerator PS Audio PerfectWave Power Plant 10
Source Lumin U1 Mini into Lampi Baltic 4
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
Soundstream's li'l Blue Wonder comes to mind. It's a 2 channel high current unit that can handle a load like that, but at 2.7 ohms per unit, the front 4 will be wired in series pairs for a 5.4 ohm load. The rears will need a separate amp for fill or just forget the rear as they'll be fairly useless against the exhaust sound.
Glenndog if your not already a member you really should check out the audio section on the HDForumn. Some very knowledge guys over there. I think For the money you can get way better than the JM stuff. Also check out biketronics.
I actually have a 2017 SGS that I have started collecting parts for a stereo upgrade.
BaggerSound there are quite a few amps that fit in the fairing. I went with the arc moto 600.4. Some others are cerwin vega b52 and b54. Jl audio mx 500/4. Several others too. Check out HDForumn audio section. -
Will do, Thanks quickr1AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12
