Polk RTA 15TL with RDO-194 tweeters
Hi all,
Haven't posted here in ages, mostly because I didn't have any Polk speakers in the mix!
I have an opportunity to get a pair of RTA-15TL with upgraded RDO-194 tweeters locally.
These would go into my 2nd system, where I generally rotate 1970s receivers (Marantz, Pioneer, Sansui, etc.) in 30-100 wpc range. Right now I have Marantz 4270 in that system.
Would this be a good pairing? I'd like a full-range sound and the speakers that the receiver can drive properly.
Thank you.
Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
    F1nut Posts: 49,806
    Those are the wrong tweeters for that model.
  • pkquat
    pkquat Posts: 744
    Yes check if they are actually 194's or if they are 198's. They are supposed to be 198's. People have said the tweeter is a bit hot, to keep up with 4 mids, and the bass is boomy in a lot of room conditions. A few searches should bring up info on that. People have done some mods to the crossovers and PRs for what they claim is a much better sound. That said, they do fall into the category of a full range speaker than can produce ample bass you can feel.
    I am not sure about the power requirements.
  • ViperZ
    ViperZ Posts: 2,046
    Here is a photo of the speakers. I'm going to go see them today. Is there a way to tell by looking from the outside, or would I have to take them out? Thank you.
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • ViperZ
    ViperZ Posts: 2,046
    The owner confirmed they are RDO-198
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • ZLTFUL
    ZLTFUL Posts: 5,640
    Where is the plastic "wing" that goes above the tweeter? It helps prevent waveform interaction between the top woofer and the tweeter...
    F1nut Posts: 49,806
    I can see the adhesive residue of where they were.
  • ViperZ
    ViperZ Posts: 2,046
    Obviously, the plastic wing is long gone...
    I listened to them for a bit with Bryston amplifier at 120wpc.. Obviously 20-30 minutes is not long enough to make up an opinion. We listened to a few songs (CDs), including Whole Lotta Love.
    The imaging was great. The highs were clear and transparent, very detailed. The mids were good too.
    Now comes the part that I didn't like. Maybe these speakers just can't reproduce what I want, but the bass sounded boomy at mid-bass frequencies. It was just obvious. And I couldn't hear the bass guitar going down to the low frequencies, it would just muddy out.
    Maybe my expectations were too high... I'm looking for something that I can drive with 30-70 watts per channel (receivers, so lower damping factor too), and expect a full range sound. Is it unrealistic? Should I go back and get these 15TLs? They are cheap, and he is 15-minute drive from me.. But I just didn't feel really involved with that type of sound.
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    F1nut Posts: 49,806
    edited August 2017
    You don't have enough power to drive them properly. They also need to be 3 feet from the rear wall otherwise they boom. Spikes help regardless.
  • ViperZ
    ViperZ Posts: 2,046
    Thank you for your input, F1nut. They definitely wouldn't go into my main system, so that's the power these will see. I actually do have ~5-6 feet behind speakers in my listening room, but the seller had them ~2-3 feet from the walls.
    Oh well, I may have to keep looking. These were way under my maximum budget, damn.
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • delkal
    delkal Posts: 764
    So how much under your maximum budget are these?
  • ViperZ
    ViperZ Posts: 2,046
    I'm looking for speakers up to $500 USD budget. These were 300 CDN, so half... I'm not really considering speakers based on how big of a deal I can get. I really want speakers that I would keep for at least several years, so if I have to go to the top or slightly over expected budget, so be it.
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • dromunds
    dromunds Posts: 9,984
    Where are you located?
  • ViperZ
    ViperZ Posts: 2,046
    Toronto, Canada
    B&W CDM1-SE fronts
    B&W CDM-CNT center
  • pkquat
    pkquat Posts: 744
    I'd say the price is fair from what I have seen. DSkip might be a good reference if you are looking for more info. This is the, or one of the mod threads.
    http://forum.polkaudio.com/discussion/48075/modifications-to-the-rta-15tl
  • [Deleted User]
    Funny how not getting that weekly pay check changes or cuts out certain things like eating or prescribed meds that are supposedly mandatory to keep you alive. Give me a party size bag of M&M's and a gallon of milk and I'm good for a week. Pretty much every project or hobby-ish thing in my life got set aside after my wife made me stop working.
