Why aren't my woofers working?
On my LS90's, the right speaker is working perfectly.
On the left speaker only the tweeter is working. No sound from the 4 other drivers.
I checked the cable connection and the jumpers and everything seems fine.
The binding posts seem ever so slightly loose. Could the internal wiring somehow have come loose??
Best Answers
    F1nut Posts: 49,795
    Answer ✓
    Sure.
    Time to open them up for a look see.
  • erniejade
    erniejade Posts: 6,314
    Answer ✓
    You can try switching the left and right cables and see if it follows.
Answers
  • hochpt21
    hochpt21 Posts: 5,423
    Sounds good. I'll crack em open when I get the chance. Just wanted to make sure it wasn't something stupid that I overlooked
    msg Posts: 9,434
    Woh. Hope it's something simple.
    Kinda funny how it's become a bit alarming to me whenever stuff like this happens. In the grand scheme, it's 'just a stereo', right? Except, no, it isn't just a stereo.
    Curious to hear what you find.
    pitdogg2 Posts: 24,560
  • hochpt21
    Wiggled the binding post and the woofers would cut in and out.
    Unscrewed them and pulled out, but the xovers were wired so tight that I couldn't really get a good look because I couldn't pull them out very far.
    Put them back in and it's working for now. Not sure if the crappy jumpers weren't connecting well enough? Or something really is loose in the xover??
    Well i see clarity cap and mundorf. Could be cold solder joint. Who did xo? Clean off that brass strap real good then see if it does it again.
  • kharp1
    kharp1 Posts: 3,453
    My policy is its fixed until it happens again, turn it up and grab a beer.
    kharp1 wrote: »
    Agree
  • hochpt21
    Yea, that's the plan for now until it happens again. I'm also hoping to make new jumpers when I get time, so that could eliminate one possibility.
    F1nut Posts: 49,795
    ^ Excellent eye ^
    F1nut Posts: 49,795
    edited August 2017
    Another observation, which may have nothing to do with your issue, but bears mentioning. Never bend the leads coming out of a resistor right at the body like in the first and last pics. Make the bend no closer than a quarter inch, which is a good practice with caps as well.
    ^ Excellent eye ^
    I agree I'd rework that joint.
    Now that I can get a good look on the work PC there are two area's there that look like they are missing solder. I would definitely rework those two area with new solder.
    See the white area
  • hochpt21
    I would have to find someone who know how to solder. Also, do you need to remove the whole thing to work on it, or can you just work on it still connected?
    You can see in the second picture those black and white wires. That is literally as far as I could pull it out, because those wires have no extra slack. And I think they are soldered in as well.
  • dromunds
    dromunds Posts: 9,981
    I would definitely make new jumpers.
