Want to stick my toe in the "power outlet"
afterburnt
afterburnt Posts: 7,892
edited August 2017 in The Clubhouse
Anyone else tried it?
  • afterburnt
    My heart is full of joy I want to rip my pants
    nooshinjohn Posts: 25,094
    Tape a butter knife to your foot first. Heard that works best.
  • mikeyb128
    mikeyb128 Posts: 2,885
    Buy some leviton or Hubble hospital grade outlets from your hardware store, they cost around 15-20 bucks, and will get Your toes wet. They have nice grip, my old plugs wouldn't hold the cords and would start to unplug.
    I've been curious in trying some furutech FPX gold plates outlets. They are around 90 bucks a piece. I love the furutech quality.
    2 channel:
    Theater:
    EndersShadow Posts: 17,528
  • FestYboy
    FestYboy Posts: 3,861
    nbrowser wrote: »
    afterburnt wrote: »
    Make sure your standing in a puddle for maximum effect...ok? :)
    I thought the puddle came afterward... :#
  • Emlyn
    Emlyn Posts: 4,369
    Tape an ice cube to the toe first. I have heard something about cryogenic treatment being beneficial.
  • afterburnt
    Darling, can you hear the fleas in my whiskers.
  • machone
    machone Posts: 1,473
    mikeyb128 wrote: »
    I used hospital grade outlets with my dedicated circuits. I was sharing my work with Mojo Audio's owner. He complemented my work but said it would be better not to use hospital grade because their plating does not yield the best sound. He recommended Furutec copper as a great choice. I plan to swap out a couple of critical outlets in the near future.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • mikeyb128
    edited August 2017
    machone wrote: »
    mikeyb128 wrote: »
    Good to know. I've often wondered the same thing. I will be replacing a few of the crucial ones in the future as well. My conditioner uses Hubbell audio grade, and can be replaced, I will most likely replace everything with furutech eventually.
    Post edited by mikeyb128 on
    2 channel:
    Theater:
  • Derf
    Derf Posts: 229
    I ran a dedicated line myself. Easy enough to do, as I have an open attic space. Used a PS Audio plug. System powers up and house has not burned.
    Integrated Amp: Marantz PM-10
    Speakers: Usher MD2
    Subwoofer: Rythmik F15HP
    DAC: North Star Design Supremo
    Streaming Source: AURALiC Aries Mini
    SACD Player: Marantz SA8004
    Power Source: PS Audio PP3 on dedicated 20amp circuit
    pitdogg2 Posts: 24,559
    What hospital grade outlet? Do you know what they were plated with? To my knowledge my hospital grade is brass but they clamp down hard on plugs which I always thought was the reason there referred as hospital grade. Surely they need to grasp good do not want life saving gear falling out.
    Obviously they're not audio grade
  • machone
    Here are Benjamin's comments regarding my recently installed dedicated circuits:
    "Looks good.
    One problem: hospital grade outlets.
    Hospital grade means they plate the contact for optimal durability from oxidation in with corrosive chemicals in high-oxygen content environments.
    Not the best for audio.
    The same companies make UNPLATED high-copper content alloy contact INDUSTRIAL grade outlets that are the best sounding for the $$$.
    Also a bit less $$$ than the hospital grade"
    "Hubble's best unplated industrial outlets for audiophiles - used in the "Porter Port" and many other audiophile products.
    I couldn't say which are the best today made by Hubble, but I do know they cost about $30 each not $5 each.
    And for $30 each for a Hubble or equivalent I would spend $70 and entry level Furutech."
    Benjamin Zwickel
    Owner, Mojo Audio
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    High O2 makes sense. Didn't think about that.
  • afterburnt
    machone wrote: »
    "Looks good.
    Benjamin Zwickel
    Owner, Mojo Audio
    I can do these
  • machone
    As mentioned before Doug carries the Furutech brand
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • kharp1
    kharp1 Posts: 3,453
    Yep2 wrote: »
    machone wrote: »
    Everyone carries Furutech.
    Yeah, but, Doug's a good guy and is a forum member, and, I think he offers a discount to forum members.
  • kharp1
    kharp1 Posts: 3,453
    I was a sucker and bought a Pangea http://www.audioadvisor.com/prodinfo.asp?number=PGNPRXL to try and see if it made a difference. Now I just need to install it. I question if it will, but, I've questioned other things in the chain only to be surprised. I'm just one of those guys that will get it just to see in hopes I can say"ehh, don't waste your money"
    txcoastal1 Posts: 13,132
    machone wrote: »
    Yep2 wrote: »
    machone wrote: »
    Doug has moved up to top tier status, and can make better deals now....just an FYI
    Heck i found a difference in the 25$ pass & seymour orange isolated ground outlet. Beat the snot out of the standard outlet.
  • afterburnt
    txcoastal1 wrote: »
    machone wrote: »
    Yep2 wrote: »
    machone wrote: »
    I will check with him first, he was always very cool with me.
  • helipilotdoug
    helipilotdoug Posts: 1,229
    We have several different receptacles that are a great upgrade from the standard and hospital grade ones. Any Club Polk members will get a 10% discount off retail pricing. We also have some on sale right now. Please PM me or go to our website and click on contact us. Let me know what you need and your Club Polk handle. If you have any questions I'll be happy to try to answer them. Thanks Guys :)
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • afterburnt
    I aint clikin it
    I reported it
    He posted in 2 threads
    nbrowser wrote: »
    Smells like......spam
    Something Posing As Meat?
    Poser like your punanani fries :D
  • kharp1
    kharp1 Posts: 3,453
    edited August 2017
    Chips?? You guys French or English??
    They're Freedom Fries...
  • helipilotdoug
    Sorry you feel that way Jesse. I have been mentioned several times in this thread, and posted links I thought were helpful.
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
