Personal Home Theater build, updated whenever
    nooshinjohn Posts: 25,100
    Trey should know by now that one good, long screw is better than several short, quick ones. Perhaps he needs a stud finder.
    VR3 Posts: 28,030
    lol!
    Those are all 1' 3/4" and hitting some real lumber! :-D
    edited July 2017
    My wife tells me that 1 3/4 would not have been enough to get the job done....
    VR3 Posts: 28,030
    Its not the size... its the quality, texture and skill set level
    edited July 2017
    quality takes time. Any wife will tell you that. The neighborhood handiman has to pay a visit if you screw hangs up and usually while you are at work.
    VR3 Posts: 28,030
    One coat - still hung up on this wall, lots of corners and such
  • mrbiron
    mrbiron Posts: 5,711
    I bet your biceps are massive from using a drill press to install drywall... ;)
  • jeremymarcinko
    Be sure you use the green lid compound for the top coat. If you don't know the lightweight compound with the blue lid has styrofoam in it. It is a pia to sand and often gets pin holes. It's perfectly fine for the first few heavy coats because it drys faster since it has less water but use the green lid all purpose compound for the top.
    VR3 Posts: 28,030
    edited February 2018
    Wife wanted the kitchen first, hang some cabinets next week
    VR3 Posts: 28,030
    The yellow wire will be an arc fault circuit, will string plug mold across the bottom of the cabinets, will have about fifty outlets
  • mdaudioguy
    mdaudioguy Posts: 5,165
    VR3 wrote: »
    I'm sorry, what? Seriously 50 outlets in your kitchen??
    VR3 Posts: 28,030
    It's plug mold, they go along the bottom of the upper cabinets. About an outlet every 3 inches... Will be sweet and you won't see but two outlets
    VR3 Posts: 28,030
    F1nut Posts: 49,801
    VR3 wrote: »
    Ok, you have officially lost it.
    pitdogg2 Posts: 24,576
    mdaudioguy wrote: »
    VR3 wrote: »
    LOL Trey does nothing small time you should see his screw allowance....
  • verb
    verb Posts: 10,176
    Hey I did a similar thing in the garage. Along the bottom.
    la2vegas wrote: »
    I'm tempted to respond but I'd better not.
    Careful Chester :p
    VR3 Posts: 28,030
    In my last kitchen me and Russ did this, it was great. Was very easy to plug in appliances like coffee makers and such without having cords everywhere. Wouldn't do it any other way. I also really like the clean back splash look versus having outlets every couple of feet. Only regular outlet is right next to the sink which is a GFI
    VR3 Posts: 28,030
    That's from the old kitchen
  • TNTsTunes
    TNTsTunes Posts: 751
    VR3 wrote: »
    Nice wire management. But what's up with the blender wire???
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
  • mrbiron
    I can only imagine what it's like to live in your house.
    One room has been sheetrocked for a year. Possible a couch with plastic on it.
    One room is sheetrocked but the microwave is sitting on the floor.
    One room is just full of inductors/caps/and wreaks of lead.
    The last room has a sink and tub installed while there is only home depot bucket on the floor. The bucket at least has a delrin seat with a little dynomatting to knock down the vibrations...
    :D
    VR3 Posts: 28,030
    Very accurate synopsis. Only thing left would be a recommendation to rotate the mattress. What a stalker lol
  • mrbiron
    Hahaha....that's Mr. Stalker to you good sir.
    Fyi, your apples are turning and your fly is down........
    VR3 Posts: 28,030
    Lol, my house is definitely a construction zone for the last few years
    VR3 Posts: 28,030
    edited May 2018
    edit
    VR3 Posts: 28,030
    Down to trimming out, then full speed ahead in the theater...errr... living room
    Clipdat Posts: 12,602
    Gorgeous tile work on the floor!
    Agree very nice Trey. I bet that was a BEAR to cut and put in.
    VR3 Posts: 28,030
    Thanks guys!
    me and a Buddy came up with that about 6 years ago. This go around I just made any needed repairs and I had to redo the 1/4" of the room where the laundry room use to be...
    EndersShadow Posts: 17,533
    Love the cascade countertop. I wanted to do something like that at our house when we remodel but I have a feeling I will be outvoted :smile:
