What tonearm cable are you using?
I was looking at my tonearm cable and wondering if i can get any improvement from going with a more, much more modern cable than what came with my tonearm ( see sig ) circa 1979. It appears to be overbuilt, more so than the factory supplied generic cables that come with most electronics over the last few decades.
Do the same things apply to tonearm cables as ex; speaker cable or ic's? If so does a bright sounding tonearm cable affect the sound like speaker cables or a bright sounding amp? Just curious as to what options might be available for me. This one connects with the five pin straight not angled to rca.
Denon AVR X4200W
Parasound A23 amplifier
LG 65" Ultra HD4k
LG 4kBR - UP970
Denon DVM 4800
Denon DP 3000 turntable
Saec 308sx tonearm w/
Dynavector 10x5 cart
Vincent PHO 701 Phono Preamp
MIT Avt3 Speaker c's
Audio Quest Big Sur ic's
Polk SDA 1C's modded
Polk LSim 707
Polk LSiM706c
Polk RTiA 3's
Polk 80F/X-RT
Polk DSW PRO 440wi sub
Infinity bu2 sub
"The early Klingon gets the Gagh"
  • mikeyb128
    mikeyb128 Posts: 2,885
    edited July 2017
    I received a fairly nice audioquest tone arm cable with the fancy battery pack on it, with my table. The table sounded very nice, until I tried a home brew cable from a friend. The significance was so dramatic, that my table sounded like shite once I put the audio quest cable back in. I now use a Frey 2 cable and it is a serious eye opener. It seems to be the most important cable in my anolog set up.
    The audio quest was such a veiled cable. I didn't think a cable carrying such tiny signals would make such a difference.
    2 channel:
    Theater:
  • Manticore
    Manticore Posts: 408
    One of the places that I frequent carries Nordost cables. Something to keep in mind.
    I must say I am very pleased with the way my tt sounds but, there was such a difference to my sound when I upgraded my speaker cables i was wondering if i could make any gains here also.
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Infinity bu2 sub
  • Manticore
    mikeyb128 wrote: »
    I too feel that my TT sounds very nice. I am almost afraid how much better it might possibly sound. I did price out the Nordost cables & they are starting around $500 to $5400 for the top liner.
    My marriage is going so well now...up to this point...goshdarnit. I may have to look into something a little cheaper. I am sure that even the AQ cable would be an improvement for ME with MY setup (over the ancient stock cable) that I am currently using.
    I also feel I am due for a retip or replacement cart soon anyway. Long Siiiiiiiigghhh. :|
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Infinity bu2 sub
    SCompRacer Posts: 8,352
    edited August 2017
    I still use flexible center conductor coax IC's for vinyl, from the table to the SUT, to the phono-pre and to my pre-amp. While the RCA terminations on some turntables were cheap, there was a reason they used coax. Low capacitance, shielding and it will pass frequencies higher and lower than vinyl produces.
    If you venture into wire IC's, ensure they are shielded and not high in capacitance. High capacitance is your cartridges enemy.
  • Mike Reeter
    Mike Reeter Posts: 4,314
    I've tried several over the years, and the best cable I've found at a "reasonable" price is from
    http://audiosensibility.com/blog/products-2/phono-cables-occ-copper-and-occ-silver/
    I'm using the Impact SE RCA/RCA and its a very cable for the money. With the Exchange Rate with Canada, I feel these cables are a bargain. Also, there is an additional 12% off sale until 8/25.
  • Manticore
    My tonearm connects with the five pin straight not angled to rca.
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Infinity bu2 sub
  • Manticore
    Those Impact SE cables look very thick & beefy. Or is that just the photo? I am going to ask the place i frequent if there are any cables i can take home to try. All the info from you guys is priceless. Nice to know what works, sounds good & not so pricey. Thanks
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Infinity bu2 sub
    pitdogg2 Posts: 24,559
    Yep2 wrote: »
    Just hard to find true 75Ω rca plugs nowadays.
    What about Canare?
    I always thought the canare rca's were supposed to by 75 ohm. I've used the with the canare coax.
    Just inquiring
  • mikeyb128
    Manticore wrote: »
    mikeyb128 wrote: »
    If you want I will give you a smoking deal on my audioquest cable. I don't see myself using it anytime soon.
    2 channel:
    Theater:
  • dromunds
    dromunds Posts: 9,981
    Yep2: I resemble those cables
    Crapshoot.
    Ive made a couple:
    [/quote]
  • Dawgfish
    Dawgfish Posts: 2,554
    I use a 5 pin-din to rca junction box by Sumiko with my SOTA Saphire and Sonagraphe SG-3 (my other decks have captive phono cables except for the Harman Kardon T-60 which has rca jacks built into the back of the table allowing use of the cable of your choice). It allows the use of a pair of the same Analysis Plus Solo Crystal Oval interconnects that I use in the rest of the system. I use a short 0.5 meter pair to keep capacitance to a minimum. It sounds great!
    nooshinjohn Posts: 25,095
    edited August 2017
    I am using Analysis Plus Solo Crystal 1.5m.
  • Manticore
    /\/\/\ @mikeyb128
    I will keep this in mind, as long as you don't want it sold and gone yesterday.
    Denon AVR X4200W
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Infinity bu2 sub
    msg Posts: 9,434
    Yep2 wrote: »
    I've made a couple:
    Nicccce.
    which RCA connectors are thoses?
    msg Posts: 9,434
    I've been curious about this stuff from KAB.
    https://www.kabusa.com/frameset.htm?/superflex.htm
    (partial screencap from page)
    edited August 2017
    msg wrote: »
    Great for tonearm wiring. I use a silver cloth covered litz on my air bearing tone arms. It offers no significant resistance to tonearm movement. Inside the tonearm and continuing to RCA termination is tiny litz coax.
    If you used this for IC's, you'd need to run it through tubing. I'd wrap it in tinfoil then sheath it. Terminations would be sensitive to strain.
    Litz is enameled so difficult to clean before soldiering. A solder pot is helpful. Wire brushing or sanding is another way though tedious. Avoid acid dip or acid core solder. :o
    Instead, and back to my favorite, coax, check out the litz coax KAB offers a little further down the page.
    Mogami wire is also another good choice for IC's though I'd still shield it. I have a Aaron (ALL212) made Mogami cable for my headphones.
    KAB/Cardas SpiralAir All Litz Coax is $4.50 per foot. Tiny, .180.
    You can see the litz tonearm wire at rear of photo. It terminates in an S video connector for easy tonearm with different cartridge swap. Like 30 seconds.
