Thoughts on SDA's...
  • lightman1
    lightman1 Posts: 10,776
    ZLTFUL wrote: »
    DSkip wrote: »
    The 3.1tl is the best stock I've heard. They paled in comparison to a fully modded pair of 2.3tl. I think for most those are the go to models. I don't know how a fully modded 3.1tl compares.
    The 2b is a nice little speaker I wouldn't mind spending more time with.
    It seems the only common ground is that dual tweeter versions are the least desirable.
    If we could convince @lightman1 to deliver his to my place, we could find out.
    No convincing needed. Get basement finished and we'll make it happen.
    pitdogg2 Posts: 24,575
    edited August 2017
    ZLTFUL wrote: »
    DSkip wrote: »
    screw that I'm closer to him than you.....
    DIBS and 3.00
  • lightman1
    DSkip wrote: »
    lightman1 wrote: »
    ZLTFUL wrote: »
    DSkip wrote: »
    You did get the spikes at LSAF right?
    I did! Thank you sir.
  • lightman1
    ZLTFUL wrote: »
    DSkip wrote: »
    DIBS and 3.00
    Let the bidding war begin!
  • jimmylee123
    In my room, with my equipment - my SDA CRS+ are better than my 1C's. The only thing I miss from the C's is the height effect from the dual tweeters.
  • FestYboy
    FestYboy Posts: 3,861
    DSkip wrote: »
    ZLTFUL wrote: »
    DSkip wrote: »
    Those would be the ones. I wish things had gone differently during my time of ownership (selling those probably being the least important of all) so that I could have done modifications to them and enjoyed the transformation. I think that is why I jumped on the RTA15TL when they became available at a good price.
    @DSkip I know you're not that far from me, I'mma gonna have to make a house call and get my ears on those 15s... Been hunting for a pair for almost 2 years on CL, and the closest I got was sold before I could pull the trigger.
  • codycatalist
    codycatalist Posts: 2,662
    K_M wrote: »
    I really enjoy the SDA Effect on some music.
    Between the 2 pairs we own, the SDA Effect sounds "different" for sure, but not sure I could say one or the other makes the effect better than the other.
    On some music I do not prefer the SDA effect. It depends on how it was recorded or just created in general.
    On some stuff I like the standard Rta11 sound or the Lsi15 sound.
    I have heard SRS 2s and SDA 2B. Completely different environments and gear used.
    The SRS 2s were in a garage and were running through an Adcom GFA555 with an Adcom EQ via Ipad.
    SDA 2Bs were in my bedroom (13x15x9) run by a Yamaha AV34 integrated via Ipad pro.
    I remember the SRS 2s being VERY bright but the bass was incredible, I wasn't caught up on terms and didn't know how to critically listen at the time so I can't comment much further or on the SDA effect.
    My 2Bs had almost as much bass but to me was more balanced than I remember the SRS's. Granted I leave tone controls at flat for everything and I believe my uncle (Owner of the SRS 2s) liked more of a V shaped sound profile. I hate to think my 2Bs sounded better but I feel like I understood them more than he did. Those speakers forever changed me and got me into vintage audio or "hi-fi" audio in general.
    My uncles idea of showing off the SDAs were to lay on the floor and feel the bass. Kinda tells me about his listening style =P
    F1nut Posts: 49,799
    edited August 2017
    I see someone didn't read the explanation of what SDA is. Once again, it is not an effect. Non-SDA stereo speakers would be more accurately described as having an effect.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    Why persist in trying to explain to a life-long flat-earther that the world is really spherical?
    The simplest explanation for the earth's shape is that, according to the laws of physics, it is impossible for something as massive as the earth to be flat. This is because, over a certain limit, the force of gravity will force a body of mass into a spherical shape. But then, the flat-earther would have to have some comprehension of physics, and specifically, how mass and gravity works. Without that prerequisite knowledge, you are stuck with "the earth must be flat because it looks flat".
    F1nut Posts: 49,799
    Call me an optimist.
  • DarqueKnight
    edited August 2017
    shanedrew wrote: »
    Asking on their own merits if there is a standout on SDA effect only.
    This question comes up from time to time. It's only natural to want to know which SDA speaker provides the "best" stereo imaging.
    The 5th generation models (SDA SRS 1.2TL, SDA SRS 2.3TL, SDA SRS 3.1TL) and the "4.5th" generation TL mod for the 1989 version SDA CRS+ are considerably better than their predecessors in sound stage size, image stability, image weight, and stereophonic holography and three-dimensionality.
    I have listening experience with all of the 2nd generation through 5th generation models. My ownership experience consists of three pairs of SDA CRS+ (stock and TL modded), SDA 2B (stock), SDA 1B (stock and modded), two pairs of SDA 1C (stock and modded), SDA SRS (stock and modded), and SDA SRS 1.2TL (stock and modified).
    The best SDA listening experience, for me, has been with the 1.2TL in a room large enough for them. There is no comparison between the sound stage rendering between my modded CRS+s and modded 1.2TLs in my two channel system, although they are both excellent performers. The CRS+s provide a much smaller presentation. However, in a smaller room, like my home office, the 1.2TLs would not work.
    So, the question is somewhat like asking is there a standout among Audis with regard to speed only. The R8 is going to be the fastest, but as far as practical performance in your driving environment, one of the other models might have overall better performance.
  • inspiredsports
    inspiredsports Posts: 5,501
    edited August 2017
    So many great points this thread could make your head explode, and absolutely on point that SDA's are designed to reproduce sound WITHOUT the effect introduced by conventional speakers that ignore the inches of mass between your ears.
    And that brings in the discussion about room acoustics and proper placement becoming more important.
    2B's (TL'd) or the progression of essentially that same basic footprint, circuitry and complement of drivers to the 3.1 TL might be the answer if you could just pick one and are on a budget.
    The big boys are pure fun and present some more challenges power-wise (and wife-wise).
    The right answer in my mind though is experimenting - - - journeying through researching, buying, modding if needed and listening for yourself.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • shanedrew
    shanedrew Posts: 84
    edited August 2017
    Post edited by shanedrew on
  • K_M
    K_M Posts: 1,627
    edited August 2017
    Non-SDA speakers are used in virtually every recording mastering and mixing studio, therefore soundstage and stereo effects are optimized in house for normal non-SDA speakers.
    Your comments are based on sales literature and the "White paper" from Polk and are in conflict with real world experiences with recording, mixing and mastering personnel.
    The Polk white paper ignores certain facts about how actual recordings are made over the last 4-5 decades and instead concentrates on a theoretical recording style that has the listener sitting in the middle of a concert hall, and hearing the sound and scope of the hall itself.
    Since almost all recordings are completely created in studio, and the resultant sound stage and stereo effect are done with normal speakers, similar to what is used in home, the SDA effect may be quite enjoyable, fun and even sound better, but it will never be a more accurate representation of what the recording engineer intended.
    Post edited by K_M on
  • polrbehr
    polrbehr Posts: 2,826
    K_M wrote: »
    So SDAs may be quite enjoyable, fun, and even sound better, even if the recording engineer didn't intend to do that. Explain to me why this is a bad thing?
  • inspiredsports
    edited August 2017
    I'm not an engineer, brain surgeon or doctorate holder, etc. so may not be understanding properly, but . . . .
    . . . . I still don't think the recording engineers in their 4-5 decades of electronic recording brilliance are compensating for the distance from left to right eardrum.
    NAD SS rigs w/mods
    GIK panels
  • machone
    machone Posts: 1,475
    K_M wrote: »
    Here we go again :/
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    heiney9 Posts: 25,080
    edited August 2017
    K_M wrote: »
    2 channel stereo is an illusion since it's been mixed and manipulated down from multi channel recordings. Do you know why? Because that is the standard consumers are willing to accept and can be mass produced for the end consumer to turn on and push play. Not because it's better or more natural, but because it a compromise (standard) that has been the most accepted therefore the most profitable.
    It's laughable that you think 2 channel stereo is the correct way to reproduce life like sound. It's not, It's incredibly flawed. SDA's provide a way to correct a few of the blatant flaws in the 2 channel mix down of a multi faceted real life event. Our ears and brains are much more sophisticated than to settle for a 2 channel mix down.
    Also SDA IS a much more realistic and accurate presentation of the real life event, not stereo. Engineers can be incredibily heavy handed in mixing and mastering for a single particular attribute. Think of them as the same as a photographer using photo-shop to manipulate their photo's for the intended final result. Not realistic at all, but altered, manipulated to produce an intended outcome other than the real thing.
    Are SDA's perfectly recreating the real event, no, but they are much closer than the same played in 2 channel stereo.
    Stereo is an illusion.
  • crashb4
    crashb4 Posts: 222
    I moved my SRS from a 12 x 15 room to a 26 x 45 room. Properly set up in a smaller room, they can be quite pleasing. Power requirements are much lower and you can't "open them up", but they still present a decent sound stage and are very detailed. Now, in the large room you can feed them power and they produce a heart pounding experience. my preference is the larger space, but they are the best speakers i have listened to in a small space.
    Schiit Freya+, Krell KAV-250a, R-Pi network streamer, 8Tb NAS, Thorens TD-145 MKIII with Ortofon 2M red, Polk: Monitor-10B, SDA-1A, SDA-SRS
  • aprazer402
    aprazer402 Posts: 3,097
    heiney9 wrote: »
    K_M wrote: »
    Excellent explanation Brock (H9), Thank you.
    F1nut Posts: 49,799
    K_M wrote: »
    No, my comments are based on superior intelligence. The mistake you keep making is thinking that SDA is based off a recording style, it is not. It is based off of the presentation to the human ears. Now, repeat that a thousand times and it may sink in, but I'm no longer optimistic about your ability to learn.
    Also to K_M, calling out Matthew Polk and a white paper as well as several patents and basically saying they are rubbish shows you either are extremely egotistical or just plain don't understand a thing about what you are saying. I'll go with the latter.
    Now would be the time to present evidence of the contrary against a well established MIT educated engineer and the evidence he presented in a white paper as well as the patents he has for said technology.
    I am all ears and eyes. Seriously, clue us clueless people in on your wisdom. I am always eager and willing to learn something new. But you need to provide me with something other than because you say so.
  • [Deleted User]
    Why isn't it used today licensed or otherwise ?
    F1nut Posts: 49,799
    It is used today in Polk's surround bars and their new upcoming SDA speakers.
    gudnoyez Posts: 8,066
    New upcoming SDA's Jesse say it isn't so, big'uns small ones spill the beans why dontcha.
    F1nut Posts: 49,799
    It's no secret, D2Lo has mentioned it and I believe there's some mention of it on either buttbook or nitwitter.
  • Conradicles
    Conradicles Posts: 6,041
    heiney9 wrote: »
    Good point.
  • Conradicles
    Save your pennies kids!
  • Emlyn
    Emlyn Posts: 4,372
    edited August 2017
    I suspect the language in the white paper referring to SDA as like being in the concert hall was intended to be simple enough for the layman to understand the spaciousness of the sound the speakers are capable of producing. A little of that language is marketing magic too. It's best not to read things too literally and extrapolate that Matt Polk must have meant SDA speakers can take a Bruce Springsteen early 1970s studio recording and make it seem like a person is sitting in the third row of the Hammersmith Odeon during a live performance by him and his band in 1975. Now of course SDA speakers MAY make Springsteen's album from that performance sound more like a "live" performance than most standard stereo speakers can, but that is dependent on proper setup of the SDA speakers and expectations of what a live concert should sound like both from the mastering engineer's perspective and the listener's. Mastering engineers also listen to sound through headphones as well as monitor speakers and make choices that they either want to or are directed to.
    The inventor of stereo in the early 1930s identified many of the shortcomings of music reproduction and perception but there was no incentive to address them back then. Polk addressed a few of them with SDA technology. What's remarkable is Polk did this not too many years after stereo speakers first became widely used in homes in the late 1960s.
  • delkal
    delkal Posts: 764
    edited August 2017
    heiney9 wrote: »
    heiney9 wrote: »
    This is something I never understood. I don't see how you can get imaging unless the song was recorded in one take with everyone playing AND it was recorded with just 2 microphones. I have some recordings like that and they do image.
    But how can you get "imaging" from laying over different tracks recorded at different times. Or from a guitar plugged straight into the recording soundboard!
    But the biggest question is how can SDA's make sense of the mixed recording that might not have any true imaging to start with.
