Parasound HCA-1000 vs. HCA-100A
  • skrol
    skrol Posts: 3,339
    I can't fully compare the upgraded caps to the originals since the originals were bulging when I got the amp. However, I certainly do feel it is worth the upgrade even to get a little more voltage margin. The originals were 60V which is right at the rail voltage. The originals were chosen because they were the highest capacitance that would physically fit the dimensions. Mr. Curl indicated that this was a shortcoming of the amp. As advances were made, higher capacitance and higher voltage spec caps became available in that same physical size.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • gp4jesus
    gp4jesus Posts: 1,969
    12Kuf/63V or 80V?
    15Kuf/63V or 80V?
    Make & model?
    on eBay.
    Nichicon 12Kuf/71V - 2/$18 shipped.
    Elnas 10Kuf/63V - 2/$10.14
    Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work
  • skrol
    skrol Posts: 3,339
    I used Nippon Chemi-Con for the power supply caps. They have a good reputation and met the physical constraints.
    Stan
    Main 2ch:
    HT:
    Other stuff:
