Want to stick my toe in the "power cord" pool...
daddyjt
daddyjt Posts: 2,322
edited July 2017 in Wanted (WTB) Classifieds
I recently acquired a McCormack DNA 225 for a very reasonable price. I am loving the amp more every time I listen to it, and I am thoroughly impressed with its build quality. The only thing I find odd, is the power cord that came with it seems of relatively small gage, considering the output of the amp.
Which leads me to considering an upgraded power cord. In complete honesty and disclosure, I have never been a believer in high end power cords. HOWEVER, I am willing to admit that that is an ignorant point of view, having never used a high(er) end power cord, and experienced the potential difference for myself. SO, if anyone has an old higher end power cord kicking around, I'd like to give one a try. I don't know that I'd be willing to go above $200-$300 for my first one, so if any of you have one you could let go in that range, let me know...
Thanks for your consideration.
"Conservative Libertarians love the country, progressive leftists love the government." - Andrew Wilkow
― Aleksandr Solzhenitsyn
«134
  • BlueFox
    BlueFox Posts: 15,251
    I started with Pangea, but once I experienced a Shunyata Venom power cable I was hooked. The Venom HC for amps is in your range, new. The Cable Company will give you a few dollars off.
    Good luck.
    https://www.thecableco.com/Catalog/Power-Cables
  • daddyjt
    Good lord... I thought $600-$800 was the upper limit. Therefore, I thought $200-$300 would put me almost in the mid-range. I am determined to try one, and I appreciate the source. If there are no members looking to sell one, I will order a new one.
    Thank you!
  • DaveHo
    DaveHo Posts: 3,480
    Take a look a Cullen Cable, namely the Gold. There are several of us here that have numerous cables from Patrick, and we are quite happy.
  • afterburnt
    afterburnt Posts: 7,892
    Screw the specs
  • [Deleted User]
    [Deleted User] Posts: 10,716
    how about a ps audio detect first? (or with DSkips WW)
    tonyb Posts: 32,906
    Harmonic tech pro11, even Steve McCormack himself suggests upgrading the power cord. Buy used and save some coin, new prices on cables is ridiculous.
    EndersShadow Posts: 17,528
    I'm a HUGE FAN of PS Audio, and Wireworld.
    I've owned Pangea and while nice, the connection just wasnt as tight as I'd like at the IEC. The thicker cables would NOT twist either without a TON of extra cable and area to bend.
    I sold my Pangea AC-14, and both AC-9's and moved to all PS Audio AC-3's. I wouldn't mind a PS Audio AC-5 at some point, but am super happy with the AC-3's and they are well under your budget of 200-300.
    Another option as mentioned by @DSkip is Wireworld stuff and they are good as well. He's a dealer so he can get you whatever you want from their menu, as it were. Also Cullen Cable, which I have no experience with, so cant recommend a specific model but its an option....
    Those 3 are well within or below your budget by a fair mark.
    Lastly Mark I know you have to remember @helipilotdoug makes and sells custom powercables.... so thats another route open to you, and I think you still run some of Dougs IC's in your system too :smile:
  • Legender
    Legender Posts: 478
    Even a brand new low end $100 Shunyata Venom will make a difference. Like you I was not a believer until I tried it. Try it and you too, will become a believer.
    Music: Oppo103 - Parasound JC2 - Parasound A21- SDA 3.1
    Theater: Denon 3808 - B&K 7500/Emotiva XPA-3- RTi12, CSi5, RTiA7x4, PSW505
    Sleeping: Marantz 70005 - Harman Kardon 2400 - SDA 2
    2 Channel: Cary 306 SACD - Canary Audio 906 - Pass Labs x250 - PS Audio Perfectwave DAC, Polk LSiM705, SVS SB13 Ultra
    Office: Dell Optiplex, Emotiva XDA-2, Adcom 5500, LSiM 703
    Spares: Yamaha CA-810; LSi 15; Kenwood Basic M2a, Yamaha M60/M80, Polk Monitor 7, SVS SB13 Ultra
    tonyb Posts: 32,906
  • Legender
    Legender Posts: 478
    Plenty of options in your price range here.
    http://www.tmraudio.com/products/power-cables
    A simple power cable upgrade can make huge sound changes. Highly recommend a little toe dipping... but after you hear it, you'll be taking the full plunge I'm sure.
  • rooftop59
    rooftop59 Posts: 7,971
    Can't believe no one has linked thread: http://forum.polkaudio.com/discussion/178085/treasure-trove-of-goodies-for-sale-two-daughters-getting-married-this-summer#latest
    MIT shotgun AC1 is right in your price range but much more new...
    Game Room 5.1.4:
    Bedroom 2.1
  • MrBuhl
    MrBuhl Posts: 2,419
    ^^ that's your huckleberry! ^^
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • mikeyb128
    mikeyb128 Posts: 2,885
    I've noticed a greater difference with power cords on my source components. The least difference I noticed was on my amp. But I think it all comes down to how the power supply is designed. Not saying there wasn't one, because there was, just to as dramatic as the others.
    2 channel:
    Theater:
  • mikeyb128
    Yep2 wrote: »
    Kimber pk10 is worth a mention.
    Used $$.
    I've actually ditched my 800$ power cords for all diy cords a friend of mine makes. All in at about 300 bucks a cord (6 footers), including furutech rhodium connectors. They smoked my store bought cords in every category.
    2 channel:
    Theater:
  • lightman1
    lightman1 Posts: 10,776
    Well sheeit..... I'll take some boogered up #10 drop cords...saw them up and add some chromium cabonate male and female terminations on either end.
    $187!
  • lightman1
    Yep2 wrote: »
    lightman1 wrote: »
    $187!
    Thats the "Farmer's Tan" talking...
    Dont knock it till you try it.
    Damn your eyes, Judas.
  • daddyjt
    rooftop59 wrote: »
    I pmd the seller of the AC1 to see if it's avail...
  • daddyjt
    I have purchased the MIT AC1 from Greg - I am excited to try it out, and I will definitely post my impressions.
    I sincerely appreciate all of the suggestions. I am very handy, and have a rather extensive electronics bench. However, As a self professed power cable "skeptic", I feel that my first impression of the difference a power cable can make should come from an established "known quantity". I have other MIT products, and I am thoroughly impressed with their build quality and attention to detail.
    Thanks again for all the great info - sounds like i may be heading down another fork of the rabbit hole... :smile:
  • lightman1
    I keep eyeballin' the Wireworld cords. They have some good reviews on their entry level goods.
  • daddyjt
    rooftop59 wrote: »
    Thank you for the lead on this cable, btw :smile:
  • rooftop59
    No problem man! Hope u enjoy it. And definitely post your impressions!
    Game Room 5.1.4:
    Bedroom 2.1
  • mikeyb128
    If the power cord is anything like their cables/interconnects, then you're in for a treat. Hopefully.
    2 channel:
    Theater:
  • kharp1
    kharp1 Posts: 3,453
    I think I have a few older Shunyata's laying around, let me check.
  • [Deleted User]
    all this power cable talk had the effect of a couple more PS Audio cables on the way.
    Thanks. ;)
  • Gerres26
    Gerres26 Posts: 862
    Now this has me thinking...is my setup good enough to warrant an upgrade in form of a power cable? Im running b&k gear through 1.2tls, what do you guys think?
