Noob's intro to HiFi forum lingo
Ok, I've been around audio (pro) for a while, but since joining here, I've come to realize that there's a new language I need to learn.
If someone would be so kind, could you define or break down the more common short hand, acronyms, or slang so that I might follow the threads with better understanding? Thanks so much.
  • cfrizz
    cfrizz Posts: 13,415
    It would be easier if you told us what words/slang you are having trouble with.
  • FestYboy
    FestYboy Posts: 3,861
    Mostly the acronyms... Like oppo
    I'm guilty of using alot of slang and acronyms in the Festiva forum and having to define or break them down for noobs there or for those over seas who use different words for the same part.
    treitz3 Posts: 18,230
    Hehe....Oppo is a company.
    https://www.oppodigital.com/
  • FestYboy
    Oh, I saw that word being slung around like it was a component, not company. Ok, so that answers that.
    I figured IC can be either interconnect or integrated circuit depending on context. TT is turn table. Are there others that y'all can think of?
    I figured this thread might help other noobs like me so if a good list can be compiled, it might be stickie worthy.
  • BlueFox
    BlueFox Posts: 15,251
    FestYboy wrote: »
    Yes. The English language allows that flexibility. That is one reason why it is a difficult second language.
  • mikeyb128
    mikeyb128 Posts: 2,885
    2 channel:
    Theater:
  • FestYboy
    @mikeyb128 that's a considerable list!
    But @Nightfall, you've got the idea I was after.
    And maybe I should add to the list: nicknames... things like Klipsch horns... I know within the context, the writer is referring to a specific model or series, but when I see that all I can picture is the actual component, and Google is almost worthless for getting the intended image.
    I'm a total noob, but dang it!, I want to learn.
    F1nut Posts: 49,708
    This is the most important one. B)
    JBH - Jesse's beautiful hair
  • lightman1
    lightman1 Posts: 10,776
    Sitting in a pool of bass..... ;)
    You'll know it when you feel it.
    mhardy6647 Posts: 32,926
    SET single ended triode
    DHT direct heated triode
    I don't think there's anything else worth knowing, actually.
    lightman1 wrote: »
    7 Hz and you might find yourself sitting in a pool of something else entirely ;)
  • vmaxer
    vmaxer Posts: 5,116
    lightman1 wrote: »
    @lightman1 = IGNORE.......
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • lightman1
    vmaxer wrote: »
    lightman1 wrote: »
    What's your address?
  • FestYboy
    You are correct Sir!!! Lol
  • voltz
    voltz Posts: 5,384
    Curtain blower's = Italian Bookies!
  • FestYboy
    Focus gentlemen, focus.... :p
  • FestYboy
    No need to bring my Celestions into this @DSkip. I was a good boy and swapped them for 11Ts as soon as I got them.
    msg Posts: 9,307
    BYSB - blows your sack back (credit: tonyb)
    This is one you have to experience to fully understand. Otherwise, it's like trying to describe a color. Plus, that conversation just gets weird, talking about the specifics of sack blowing, ripple effect, sustain, etc.
    You'll know it when it happens, or so I hear. I've just taken to BYSB Emulation with a couple of big fans with proper toe-in, but I don't think it's the same.
  • vmaxer
    vmaxer Posts: 5,116
    la2vegas wrote: »
    vmaxer wrote: »
    lightman1 wrote: »
    vmaxer wrote: »
    lightman1 wrote: »
    1600 Pennsylvania Ave.
    Hurry, bring lawyers guns and money. B)
    What, no strippers? You got to bring those.
    Some things go without saying, @lightman1 knows to always have strippers tag along.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,116
    la2vegas wrote: »
    vmaxer wrote: »
    la2vegas wrote: »
    vmaxer wrote: »
    lightman1 wrote: »
    vmaxer wrote: »
    lightman1 wrote: »
    He did come off as a man's man. ;)
    Met @Lightstar1 and @EndersShadow last Saturday. Good guys, (may be a stretch for the notorious @lightman1 ) >:)
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • daddyjt
    daddyjt Posts: 2,305
    A few random ones...
    SS - Solid State (transistors, not tubes)
    OTL - Output TransformerLess - a specific type of tube amp
    Caps - Capacitors
    OB - Open Baffle, a type of speaker that is typically without an enclosure
    DSP - Digital Signal Processing
    DMM - Digital Multi Meter
    SW - Sub Woofer
    MIT - Musical Interface Technology - very high end cables
    OFC - Oxygen Free Copper
    FR - Frequency Response
    FWIW - For What Its Worth
    BTW - By The Way
    IIRC - If I Recall Correctly
    IMHO - In My Honest Opinion
    IIWM - If It Were Me
    WWJD - What Would Jesse Do
    "Conservative Libertarians love the country, progressive leftists love the government." - Andrew Wilkow
    ― Aleksandr Solzhenitsyn
  • FestYboy
    YMMV? The first M is what gets me? Usually there's an R in that position.
    DAC = digital analog converter
    Pre/pro = preamp processor
    nbrowser wrote: »
    Would like to buy some hair product?
    No need, my hair is perfect.
    https://youtu.be/9DryqGwNyfU
    Critic Steve Simels said (approvingly) of this album when it was released: "It'll kill your house plants." High praise indeed.
    aooooooooooooooooooooooooooooooooooooooo
