Tube Cool Down Q
kevhed72
kevhed72 Posts: 4,950
What's a safe time to swap out pre amp tubes....I'm stalling on my real work and decided to pop in another set
    pitdogg2 Posts: 24,477
    when they are cool :p Honestly I have a pair of rubber coated Kevlar gloves for steel work I found work great. First I bought them for a steel roof I was putting on and then found they work great for not touching tubes and leaving skin oils on the tubes. IT just happens that they are great insulators for hot tubes.
    heiney9 Posts: 25,053
    I use rubber gloves and for signal tubes I usually wait like 5-7 minutes before swapping. But really, you could do it right after power down. Rectifiers and power tubes are a different story.
    mhardy6647 Posts: 32,926
    Other than a rectifier tube, most preamp tubes should run pretty cool and require minimal cool-down. This being said, you might find some components that run even small signal tubes hard enough to get 'em hot... but most of the time, in well-designed preamps, the small-signal tubes shouldn't be what I would consider hot even when up and running at steady state.
    Power tubes and HV rectifiers are worth waitin' a few minutes before touching, though ;)
  • lightman1
    lightman1 Posts: 10,776
    I had St. Elmos fire going in an eight set of 6550 power tubes.....No touchy for a long time!
