Monitor Series 2 M4 vs. M5
How similar are these sonically? I'd like to find 3-4 more M5's but none are to be found at the moment. I can fill out my system with M4's but haven't heard them for comparison.
The Series 2 uses a very different tweeter, so not a good timbre match to the Monitor 5.Political Correctness'.........defined
President of Club Polk -
Hold out for 5'sStan
Main 2ch:
HT:
Other stuff:
Or if you're in a pinch, the 5JRs with the passive should work better than the 4s...
But I'm with @skrol, hold out for more 5s if you can stand it. -
Interesting. I was under the impression these were the same speaker but that the M5 had the passive radiator and the M4 did not as the only real difference.
Perhaps I misunderstood, are both the Series 2 versions? If so, they will work perfectly with each other.Political Correctness'.........defined
Yeah. They're both series 2. Are they virtually identical or will I find the M4s lacking in low end?
Either will need a sub to fill the bottom end. Other than that, they are timbre matched.Political Correctness'.........defined
The M5 has great low end. You're right, it could use a sub but will the M4 have as good of low end but just in a smaller package?
^ no, the M4s will definitely lack in the bass department. Smaller box coupled with a tiny shallow port limits the low end extension. The JRs will put up a better fight against the 5s than the 4 or 4+ (4+ is a taller box with the same small port).
I had Monitor 5A (peerless), and Monitor 5B (SL-2000 fisheye) and the bass of the 5B was much better than the 5A. I would think the Monitor 5 Series 2 are at least as good in bass and the SL-2500 was much better than the SL-2000. You can also TL mod them and use the RDO-198.Stan
Main 2ch:
HT:
Other stuff:
Correction to previous post: 4+ should be 4.6, but discription is the same.
There are several Series 2 M4s on eBay right now as well as some Series 2 M4.5 and M4.6s. I can hold out for Series 2 M5s but don't want to have to wait a year or more. I'd be willing to give either the M4 or 4.5 or 4.6 models a try or even a 5jr. What would you guys do?
Personally, the 5JRs, hands down.
Love my M5jr+'s but haven't heard M4's. The M5's are nearly as good as the M7's I sold, both of which have the SL2500 tweeter.
I have had the Monitor 5 Series 2 with SL2000 and another pair with SL2500s. The 4s will lack in bass for sure from the one that I heard (square tweeter). Can't comment on timbre matching as I didn't do a side by side. Where are you located @thechris I know we have 2 pairs of M5s here in Phoenix Craigs list.Just a dude doing dude-ly things
