Is a DAC gonna help, particularly an iFi Micro?
I have all but forgotten my Parlor HT 2 Channel system for music, it's only acceptable SQ is through the Oppo 103 DAC (which probably sucks to most of yooz). I want to at least try a separate DAC for the time being and I love how versatile this iFi Nano is so I am partial to the Micro version for its increased versatility and it's positive reviews. What sayz yallz, anyone running one?
  • Absolute_Zero
    Absolute_Zero Posts: 72
    edited July 2017
    AudioScienceReview.com has been benching a good handful of $99 and under DAC's.
    The $349 iFi DAC2 didn't fare as well on the Jitter reduction testing that was done vs the $79 Behringer 204HD. So food for thought. The 204 also will have a significantly lower noise floor with balanced outputs.
    You have a good DAC in the Oppo and don't see you doing much better.
    I don't see a $129 iFi doing better but if you can try it out with an option to return...
  • afterburnt
    afterburnt Posts: 7,892
    http://ifi-audio.com/portfolio-view/micro-idsd/
    This is the one that I had in mind. Which one did you see for $129?
  • You said the iFi Nano the Micro is a different offering from them.
  • afterburnt
    I have the Nano, I want to try the Micro. Where did you see the Nano for $129?
  • afterburnt
    o k i c nano l e
  • voltz
    voltz Posts: 5,384
    Hey I forgot I have one & you asked me before and i forgot to answer it as I think I changed the subject before answering :# my bad!
    you know those cans I'm sending you? I'mm put this in there too as I not using it much these days because of my Auralic mini dac/streamer
    so try it out with the Senn's and the Hifimans I'm sending. but you have to do a review afterwards :p I hate doing reviews!
  • afterburnt
    LOL, I can't do big word reviews. Mine are usually like: These are great or this kindda sucks, glad I didnt pay too much for em".
    Anyway, do you have the "Micro"? What do you think of it and what is your goto headphone amp?
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,722
    IMO those LSiM speakers aren't resolving enough to make that kind of DAC upgrade worth it. If you were upgrading from straight out of a portable device or something with a terrible design to a great DAC then I'd say go for it, but going from the 103 to an entry level external DAC won't net you much if any improvement.
  • afterburnt
    Thanks, @AsSiMiLaTeD, I may get one anyway for headphone duty on my 2 channel. If I didn't say so this is a stop-gap thing. When I move the LSiM will be strictly HT.
  • rooftop59
    rooftop59 Posts: 7,968
    afterburnt wrote: »
    Are you really telling me that the DAC in the Halo P5 is worse than a little $200 portable DAC??? If that's true then I am really glad I only have cheap stuff lol...
    Game Room 5.1.4:
    Bedroom 2.1
  • afterburnt
    edited July 2017
    rooftop59 wrote: »
    afterburnt wrote: »
    Not at all. The Oppo 103 sounds substantialy better than the P5. Most would probably say the Oppo Dac is not top shelf. Reviews say that the $550 Micro sounds better than my Nano so I want opinions if anyone knows the piece and could it be an improvement. Fwiw the P5 dac is too laid back for the LSiM's.
