Infinite Baffle
    EndersShadow Posts: 17,528
    VR3 wrote: »
    Ive been checking used sites off and on and finally nabbed a pair of 18" IB13 FI subwoofer drivers for $295 a pair (local pick up-how lucky??)
    ... now to find an XTI2000 amplifier... badass sub for like $550?? cant beat it!
    I think your MONSTER sub would be better, and look like furniture to boot... but thats neither here nor there :smile:
    VR3 Posts: 28,020
    yeah but one takes up 0% floor space and the other takes up like 1,000% floor space lol
  • FestYboy
    FestYboy Posts: 3,861
    txcoastal1 wrote: »
    Here are the pics of Matt's install
    Holy cow!!! That looks awesome! How's the ceiling deal with the piston motion of the air slug in the box?
    txcoastal1 Posts: 13,132
    He hasn't had any issues so far. His parents who live next door thought an earthquake was happening.
  • FestYboy
    VR3 wrote: »
    I think that is YOUR thumb @lightman1
    Is it me, or does the box have 3 different size drivers? What kind of configuration is that?
    FestYboy wrote: »
    That was a box built with a design similar to a VMPS Larger sub using higher excursion TC Sounds LMSR drivers.
    The Larger used a active 15 & 18" driver with a 18" passive on the floor that acts like a port.
    Here is the sub it was eventually going to look like...
  • FestYboy
    Interesting. According to convention, the passive should have at least 1.5x the pistonic volume capacity of the active driver. But in that box, there are 2 active drivers, one being the same size of the passive, which would suggest that the passive could potentially be pushed past it's x-max. I would have thought that only the 15 would have been active...
    FestYboy wrote: »
    VR3 wrote: »
    Another pics of Russ' sucking thumb... :s:s:s
    FestYboy wrote: »
    Yup... but only Trey, Tom and Russ know how it sounded as they all heard it before it was sold off for parts...
    From my understanding it was bucking Russ off it and thrashing around the floor like a bucking bull with only 1k of wattage from a Pro amp lol....
    VR3 Posts: 28,020
    The passive was an 18", actives were a 12 and 15 and that sub was just stupid nuts
  • FestYboy
    Makes me want to recreate that box!!! I like a good ruckus :D
    VR3 Posts: 28,020
    XTI2000 should be next week some time... so far have about $600 in this configuration... not bad at all considering the performance people talk about.
    Will be very hard to not cut some holes in the floor very soon!
  • Conradicles
    Conradicles Posts: 6,036
    Very nice. Where did you decide to mount the subs? Floor, ceiling or wall?
    VR3 Posts: 28,020
    So I did a "bass walk" and the location I plan to put the hole is the left front corner of the room in the floor. I think this will provide the best bass response.
  • mrbiron
    mrbiron Posts: 5,711
    VR3 wrote: »
    Waaaaahhhhhhh.....in the floor?! :a
    Remember, when cutting, ask yourself, "what would Wile E. Coyote do?"
    treitz3 Posts: 18,316
    VR3 wrote: »
    Is the listening position still almost directly in front of the front door, about 4-5' out from the door?
    VR3 Posts: 28,020
    For Music, yes. For movies and such, will be left corner, left of door
    VR3 Posts: 28,020
    If I find another pair of fi drivers used, i could see adding another pair in the future
    VR3 wrote: »
    All the bass!!!!! I want ALL THE BASS!!!!!
  • Dennis Gardner
    Dennis Gardner Posts: 4,860
    VR3 wrote: »
    2 IB drivers will only equal 1 single box driver. I think that you will be underwhelmed unless you have heard one before. The bass is cleaner, smoother, and deeper but will lack impact and the heft/mass that a huge box sub delivers. You will reach Xmax with very little power applied and thus headroom will suffer. I would make the manifold to accept another pair easily or plan for a second one in the other corner.
    VR3 Posts: 28,020
    Honestly the Mezzo Utopia has it covered down to about 30hz... I really don't even need a subwoofer for (most) music.
    What I am really hoping for is the low end extension and a little bit of reinforcement above 30hz. My room is also not tooooo huge, 22'x16'x8'
    VR3 Posts: 28,020
    3" excursion -vs- direct servo...
    Game. Set. Match, behaucth.
    The end result will be what it is. Infinite baffle versus Direct servo.
    Who will win?
    Let your ears decide....
  • Dennis Gardner
    Nice looking pooches, is the brindle a Plott?
    VR3 Posts: 28,020
    thank you sir! All mut, both of them. The brindle from what I can tell is a boxer/pit bull mix.
  • inscrutable
    You are going to love an IB. Have heard several. Not sure why, but have seemed to integrate and call less attention to themselves with music yet call plenty of attention to themselves with movies
    Sooooooo...........................
    @VR3
    VR3 Posts: 28,020
    Lifes been busy man, I'm like the little engine that could :)
    VR3 Posts: 28,020
    VR3 Posts: 28,020
    Guys, you undersold the crap out of this idea
    I am simply blown away what two of these freaking woofers can do. I thought I needed more and actually acquired 6 of them but I am just going to do 4, two per side of the room
    The quality and extension of the bass is absolutely stupid
    Jeez
