Polk Signature Series Official Discussion
1111214161730
    mhardy6647 Posts: 33,020
    lightman1 wrote: »
    Infinity RSII can drop to 1/2 ohm loads. They are famous for killing amplifiers that aren't up to the task.
    -- as were the original Quad ESL-57 electrostatics :)
    source: http://www.quadesl.com/quad_main.html
    They're essentially large capacitors that make noise ;)
    They present nearly a short circuit to an amplifier at frequencies ca. 10 to 20 kHz.
    Fortunately, when appropriately driven, they make truly wonderful noise.
    11037532424_40fafabb81_b.jpgParamours and Quads 112413 by Mark Hardy, on Flickr
  • lightman1
    lightman1 Posts: 10,776
    lightman1 wrote: »
    I knew there was a reason I liked you, Doc. Just couldn't place it until now.....
  • Dabutcher
    Dabutcher Posts: 2,591
    I just traded a pair of Polk Rti-A1's in Cherry that I had no use for , for a pair of S20's. I will keep you posted of impressions. Peace. D
    msg Posts: 9,423
    Niiiice!
    I'm also auditioning some S20s as well. Got about 36hrs on them so far. Not gonna say too much yet aside from that I'm impressed with what they've done with this line. I certainly like them better than RTi(not -A) series.
  • K_M
    K_M Posts: 1,627
    txcoastal1 wrote: »
    Keep in mind that the output rating on receivers is measured at 1khz
    In addition to that it's not all about the watts but also current that the amp will provide
    Some yes, but this is what you need to truly see what they do!
    https://www.soundandvision.com/content/yamaha-rx-v473-and-rx-v573-av-receivers-ht-labs-measures
    tonyb Posts: 32,906
    K_M wrote: »
    txcoastal1 wrote: »
    ...and some yes and no to that also. Nowhere does it give a measurement of current available, which is more useful than watts. The novice would look at those numbers and scratch their heads anyway. To be fair, most receivers don't publish an amperes peak to peak number, and for good reason to not embarrass themselves.
    Interesting enough, from that link....
    Yamaha RX-V573 A/V Receiver
    Five channels driven continuously into 8-ohm loads:
    0.1% distortion at 20.8 watts
    1% distortion at 24.9 watts
    Seven channels driven continuously into 8-ohm loads:
    N/A (protection engages)
    So with 5 channels driven, your smacking a top end of 25 watts, with 8 ohm speakers.
    7 channels, the auto protection engages so it's pretty much going to be a cupcake for anything over smallish speakers....and only in 5 channel mode.
    That's what people need to know, in plain English. Just sayin'
  • K_M
    K_M Posts: 1,627
    tonyb wrote: »
    K_M wrote: »
    txcoastal1 wrote: »
    Well in all fairness, most of the 5 channels never run full range. Usually a subwoofer is used and that changes things drastically as far as power goes.
    We have one set up where we tried one of our cheap Yamaha AVR's, and running 2 Lsi15's it was quite capable.
    Our separate amp did better for sure, but not "That" much better if that makes sense.
    Not the ultimate in high power, but frankly, was much better than we were expecting.
    When running a sub, below 100hz, the output with 2 speakers is more than enough for most levels we would ever use.
    I agree better to have "More power",but at the same time, think AVR's are more capable than they are being given credit for.
    tonyb Posts: 32,906
    True, they are not run full range, the difference being in the drastic changes a movie soundtrack has. Those surrounds can be quiet as a church mouse one second, and a cannon shot in the next. Those quick transient responses require reserve power to handle, or that cannon shot sounds like a cap gun. Music is the same way.
    Running in 2 channel mode, you'd probably not have to worry about anything with fairly efficient speakers, but speaking for myself....I wouldn't even consider putting it on a 4 ohm speaker, unless you listen at very low volumes, but then your listening without any real dynamic impact.
    Turning up the volume will put stress on the receiver, introduce distortion....as the specs show, and possibly do a smoke dance around a tweeter or 2. Point is to err on the side of having too much power than you need, not walk the line between too little and possibly doing damage. Make sense ?
    F1nut Posts: 49,781
    K_M wrote: »
    tonyb wrote: »
    K_M wrote: »
    txcoastal1 wrote: »
    The conclusion I get from your comments is that your separate amp isn't very good to be not much better than a low powered AVR.
    heiney9 Posts: 25,079
    edited June 2017
    Scale, that's the word everyone should be inquiring about.
    A mere receiver can't reproduce the "scale" of the performance or movie because in most cases it has a puny power supply.
    Everything will play music, but trying to get dynamics and scale you need reserves and well designed gear and cables too, cables matter.
    P.s. also as you delve futher into the hobby watts really don't matter unless you are trying to achieve high levels of SPL, which is not scale or dynamics, related in the entire equation, but not the same. It's a balancing act and receivers sadly don't cut it for serious audio reproduction.
    tonyb Posts: 32,906
    BTW...my post wasn't intended to call anyones baby ugly. Just to inform, maybe show what those numbers mean when put into application. I just used the info already posted.
    We always get a lot of questions about receivers and what they can or cannot power. Everything has it's limits for the applications people want to use. Your basic receivers from entry level to mid level from all the major big box store brands have either a 450 watts or 750 watt power supply, give or take a few. There is always exceptions too, like Nad usually under rates their power, unlike the others who exaggerate it.
    A receiver that can't power 8 ohm speakers in 7 channel surround mode, and goes into protection, is a tell tale sign of a weak power supply and one should be careful on the speakers they select to use.
    THAT is what those numbers mean in plain English for people to understand. Not trying to insult anyone's gear or look down on it, just trying to set the record straight on published specs and what they mean for real world applications.
    txcoastal1 Posts: 13,132
    Back to the OP's new speakers is it will do fine. I was just commenting on the math specs before my post
  • K_M
    K_M Posts: 1,627
    tonyb wrote: »
    All of what you say, makes sense in theory, but we have actually tried Running 4 ohm speakers as I said, and while theory says not a great idea, it was nowhere near as bad as we imagined is all I am saying.
    FYI, it would play fairly loud and still sounded decent is all. It did get a bit warm for sure, but never distorted or shut down or made the music sound bad.
    What AVR's have you tried this "Torture" test on?
    Are you speaking from actual experience or what you have heard?
    edited June 2017
    "Decent" doesn't cut it for some of us. That's the other side of the coin you always conveniently miss when you are opining. You assume since it sounds decent to you, it's acceptable to all.............it's not.
    P.s. once again your viewpoint is the only one that's correct because you keep trying to nail it home. Not all of us accept "decent sounding", we strive and achieve for more. It's Ok to have a decent rig, but don't dismiss others because they want more.
    tonyb Posts: 32,906
    K_M wrote: »
    tonyb wrote: »
    I've tried it on many receivers, like Sony's and Pioneers, granted older. Only I can hear when something is stressed and don't push it or discontinue using it. I don't wait for a driver to go south. I don't call the sound "decent" either, I listen for the signs of stress.
  • K_M
    K_M Posts: 1,627
    edited June 2017
    tonyb wrote: »
    Makes sense, and I am just trying to set the record straight based on actually having Tried a few AVR's in real world applications and finding, they were not nearly as bad as several have described them to be.
    I agree a separate power amp will be better for sure, that is not the argument.
    I wonder truly if everyone downplaying AVR's has actually sat down and tried a few?
    Or if their comments are based just what they read.
    With my Pioneer and Oinko avrs, I never got full range dynamics. Kids had nearly clipped my speakers playing games and music. People show up here all the time with blown tweeters, and xovers, when they had to much of a good time, turned up the volume and clipped the system.
    It's going to happen to everyone at some time or another, due to lack of understanding.
    Drop some hip-hop or techno on a cheap AVR with some larger speakers, mix in a few beers and a party...poof. I get it, but it happens
    msg Posts: 9,423
    edited June 2017
    Kelly, curious, which Yamaha amp is your cheaper one? I ask so that I can compare it to my own experience. I have a friend who's big into Yamaha as well. He's the one who got me into Polk speakers in the first place.
    I've always noticed improvements with standalone amplification. Even smaller amplifiers, like the Parasound HCA-1000 (125wpc) or a B&K Video 5 (105wpc). The music is fuller, clearer, and more controlled. With AVRs, my experience is that things can get congested, for example, and I've lost stereo nuances.
    Experiencing these types of improvements, I, personally, get spoiled pretty quickly, and I wouldn't want to go back to lesser experiences. That would be a bummer for sure.
    Here's an example.
    I remember trying to run some RTi10s with an entry Pioneer VSX-521k when I first started. That AVR was advertised at 110W x 5. Coming from some older stereo receivers, one only 25wpc in much heavier chassis, I thought, wow, cool! This new receiver is 4 times more powerful!
    How wrong I was. Just sounded so tinny and empty. I had to turn on the Advanced Sound Receiver function (emulation/boost of some sort) to get the speakers anywhere near listenable with any amount of bass and still little to no midrange. That or the top end was just overwhelming everything (speaker design)
    Added a 200wpc B&K amp I found locally (I never get deals, but I did this time)
    PUNCH!
    I did have to run a different preamp, and the speakers still weren't good for music, ultimately, but they performed unquestionably better. Why? That B&K amp specs at 75A peak to peak. The low frequency drivers needed higher current amplification for the impact and control that those speakers are capable of and to produce more balanced sound instead of just vibrating the mid and woofers while the tweeter screamed. And screamed. And Screamed. Control and clarity were improved, while congestion and distortion greatly reduced by lifting the dam gate. The speakers were IMPACTFUL on that amp, just... owned.
    The net effect? I was able to get fuller sound at a more modest listening level without having to crank the volume just to feel like I was getting things moving.
    Higher end AVRs can probably do much better than that little Pioneer I had, and perform acceptably, depending on your speakers, goals and expectations, but for some speakers and enthusiast 2ch enjoyment, AVRs by themselves can't really match external amplification for these kinds of refinements with demanding speakers. And then there are the refinements that a lot of people don't even know about, like imaging and depth; decay. Profound experiences still elude me, but I've had a taste.
    Without an amp can you get sound? Of course.
    Will it be pleasing? Questionable/Subjective, and dependent on your measure and prior exposure. Sometimes I curse ever having found this place, but wouldn't trade the experience and knowledge gained.
    Post edited by msg on
    F1nut Posts: 49,781
    K_M wrote: »
    tonyb wrote: »
    Perhaps the real question here is have you sat down and tried a few high end amps and if so, which ones? I ask for specifics because you're always so vague. You also talk in circles to avoid answering specific questions, so I'm hoping for something different this time.
  • vmaxer
    vmaxer Posts: 5,116
    K_M wrote: »
    tonyb wrote: »
    I have tried and still have 3 or 4, I find what Tony and H9 are saying to be very accurate, your statements,,,not so much.
    I fried tweeters and crossovers using a high end "at the time" receiver on a set of LSi15's.
    Moved to separates and haven't had any issues at all, and play at a lot higher volumes at times, especially on movies.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    edited June 2017
    heiney9 wrote: »
    This is a one size fits all universal statement that is not true. For example, there are huge differences between the Yamaha low end RX-V line to the top of the line RX-A Aventage 3060 for rms watts, their power supply and dynamic power, etc. Different receivers have "punny" to robust power supplies. Each should be evaluated and stand on their own merits.
    Very few if any can compete with a well engineered, well built separates. Sure it's a general statement and it rings true 95% of the time. Dynamic power ratings are a joke in many instances, just the manufacturer skewing the numbers. There is no real world application for dynamic ratings since they are achieved in an unrealistic situation that would (could) never happen in a typical home audio system.
    No such thing as a "robust" AVR power supply. It's physically impossible to contain in a standard chassis. I'm talking one that runs all channels the same and can achieve high levels of headroom.
    All that said, there are separates out there that don't cut it either. It's not a one way street. But there are less "puny, just decent" separates out there vs. AVR's that are puny and just decent. Some are a step above decent, but not close to the level of good separates.
    edited June 2017
    I also suspect many here that are touting AVR's as excellent have never heard a really good amp/pre-amp combo.
    The clarity, dynamics, precision, air, space and shear scale would blow your skirts up more than you know.
    For some it comes down to "those that don't know, don't know that they don't know"
    I'd also suspect some just won't/don't care and are fine with "just decent". Which is perfectly fine.
  • K_M
    K_M Posts: 1,627
    msg wrote: »
    Here's an example.
    PUNCH!
    Our "cheap" one is called the Yahama RX V373. We also have one of their "almost" top of the line ones, called Aventage, but do not have it as the house I am at now, so can not truly say which model number.
    I have seen descriptions all over the place regarding AVR's, so hard to say what is what.
    As I have said before, way too many variables, and way too many subjective impressions to come to any real conclusions.
    I have seen descriptions regarding AVR's as if every single one is identical.
    I have read professional reviews saying some have great sound etc.
    Not an argument here, but simply the revolving world of audio.
    msg Posts: 9,423
    Cool. Yeah the Aventage models get some nice support. I've also been curious about some of the higher end Onkyo stuff, too. Got a soft spot for them. Onkyo was the first receiver I ever bought of my very own when I was in my 20s. Two weeks ago.
    Okay, yeah, your RX-V373 seems to be similarly specced to that Pioneer VSX-521K. Could work just fine depending on what you're driving with it, and sounds like it's working to your liking. And yeah, if you're crossing to the sub at 100Hz, you don't need much going to the speakers. Are those satellite type speakers or bookshelf ones?
    I think it all boils down to getting your ears on as much stuff as you can. You can read reviews and opinions until the end of time. IME this just gets circular and confusing after a while, and until you get ears on stuff to reconcile and give context to what you're reading, it's all just relatively meaningless.
    Even after I started collecting - okay, I'll admit it: hoarding - stuff, I still had to spend time with each piece or component to get a proper sense of how it performs. I have my reference music to use for comparisons, but even still, I need some time to settle in with stuff, listening to pieces and passages over and over again, and then I can switch stuff around to see which I prefer best.
    I know what I don't like, at least.
    tonyb Posts: 32,906
    Part of this too, is knowing what to listen for, in determining if your gear is under stress. Many don't know, anyone can plug anything into anything and get sound.
    It's not a matter of this or that receiver is a piece of junk, it's a matter of putting together pieces that compliment each other both in power and sound. Many receivers I've heard sounded darn good, combined with the right gear and speakers.
    tonyb Posts: 32,906
    msg wrote: »
    ....AND that's a good portion of the journey my friend. :)
  • K_M
    K_M Posts: 1,627
    edited June 2017
    msg wrote: »
    I have tried it with about 5 sets of speakers now, ranging from a few bookshelfs to the lsi15's and Rta11t's
    Nothing sounded puny or weak though, in fact that was why I was so shocked. After reading many comments about how truly horrible an AVR would sound, left thinking either some are exaggerating a good bit to prove their point, OR, maybe AVR's vary a lot in sound quality, and I have not heard heard enough of them to hear one that is truly bad.
    Then it occurred to me. I read some reviews on that site I linked to. Not to my actual model I own, but its newer replacement, and a few steps up and I read just about every AVR review.
    Seems the reviewers came to different conclusions based on model and brands, and also to many of the comments in here.
