Driver/Speaker rings for your vintage Polk SDA's Monitors..
Hi Larry,
I need a set of rings for my Monitor 5As. Will any of these work?
The drivers were originally MW6500s but may be changed to MW6516s. -
Hi Larry,
I'm guessing that the ones used for the Monitor 7s will work? Unless the rings include rings for both the drivers and prs? I really only want rings for the drivers... -
On my second ring installation (right speaker) into my 3.1TLs, I discovered that there is an overlap between the tweeter rings and the 6" rings above and below it. So one of the rings won't lie flat against the inside of the soundboard. I intend to grind down the overlap with a belt sander, but does anyone think it worthwhile to fix the rings I already installed in the left speaker?
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro -
Just break off the round ends of the tweeter brackets and use those for the tweeters. Larry is a very smart guy, he designed them to break off if need be.Political Correctness'.........defined
President of Club Polk -
Thanks F1nut.
Then I guess I could have left the hurricane nuts in place.
Jim
5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro -
I have a newb question. Price is for a pair of speakers or priced individually?
Pair..
I still have some, depending on what you need..
Sent you a PM
If you decide to make a set for the SDA 1.2TL let me know. I would love to have a set.
As soon as I get time to do a count on what I have, I will update here, and those of you that have PM'ed me..
Thanks for being patient... -
No problem, I'm enjoying listening to them now. One member did the tweeter upgrade another the crossovers I might as well add the rings.
Thank you for the update. -
If you're still making these, I'll take a set for a pair of SRS 2's.
Amazing that all these years later. The ubiquitous Larry's Rings are still the must have of upgrades.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
Guys I'm trying to get some things together here, but we have been very busy... Hopefully soon...
Larry, put me down for a set for the 2.3 TL please.
If you have tweeter brackets as well then I will need 8 total....6 for 2.3TL, and 2 for the 2B TL.
Thanks. -
Hey Larry ,Full set needed for SDA SRS including tweets ,speaker con plate and crossover plate.
Thanks -
Just to clear things up, I have had quite the demand lately for the rings, I don't want any of you thinking I'm not seeing this, or not hearing you..
Just so you all know, the shop is slammed at the moment, as well we will be moving the business starting next week, this will be a huge deal for us trying to keep production going as well as moving equipment, we have been preparing for the move the last few weeks as well..
So to sum it all up, it will be a few weeks before I can jump in the ring so to speak..
Hope this helps, and hope you all can wait for a few, but I will get to them...
Thank you... -
Thanks for the update. Good Luck with the move.
Guys the tool man has a ton on his plate at the moment. It may be sometime before he steps up to do another run. In the meantime go with hurricane nuts.
He's right, I do have a lot going on right now, and as far as my projects I'm using it as a means to keep my mind busy, I realized I needed something to keep me busy outside work..
Hi - just signed up here for this request specifically - Larry - I need a set for 2.3tl's Pahleeeze! Thanks - Dave
Dear Larry, would like to reserve for 1 set for 2.3TL. Thanks so much!
WOW one post and BANNED now that folks is a new record
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
I saw his avatar, which I'm sure is why he is now banned. So, instead of reaching out to the newbie and explaining why his avatar isn't acceptable he gets banned. This is going to keep a customer how???Political Correctness'.........defined
are you serious ? double WOW -
It certainly is not a comon sense approach. Why not put something like "N/A" in the avatar area and let him stay active."Sometimes you have to look to the past to understand where you are going in the future"
Harry / Marietta GA
