Plinius P8 amplifier
haimoc
haimoc Posts: 1,031
edited May 2017 in For Sale (FS) Classifieds
For sale is a Plinius P8 (200W / 8ohms or 300W / 4ohms). The amp is in excellent condition with original boxes. I lost original manual, but I can print a copy of user manual from the PDF file to include with this amplifier. $1300.00 including standard ground Fedex. Paypal (plus fee) or USPS money orders. I upload pictures later today.
Plinius P8 Specifications:
Power: 200 Watts RMS per channel into 8 Ohms both channels driven from 20Hz to 20kHz at less than 0.2% total harmonic distortion..
Frequency Response: 20Hz to 20kHz ± 0.2dB. -3dB at 5Hz and -3db at 70kHz.
Distortion: Typically less than 0.05% THD at rated power, 0.2% THD and IMD worst case prior to clipping.
4 Ohm Power: 300 Watts per channel or greater.
Current Output: 40A short duration per channel. Fuse protected.
Slewing: 50V/uS.
Hum & Noise: 90dB below rated output 20Hz to 20kHz unweighted.
Input Sensitivity: 1.75V RMS for rated output at 1kHz.
Input Impedance: 47,000 ohms.
Gain: 27dB.
