Polk gets it, re: power ratings
Looking at the Owners Manual for the Polk Signature Series, we find the following recommendation on power requirements: "we recommend using amplifiers and receivers with rated power above the rated Power Handling limits of our speakers because having extra power available for short term peaks is conducive to better sound quality, maximum dynamic range and effortless high volume output. But we strongly urge you not to use the full power of your amplifier or receiver for daily listening."
Now those that are touting 'more power' are vindicated by the manufacturer. An easy way to show the wife a current system is under-powered.
Mr. Watkins complained of my little receiver and it's rated power output in the 80s when I bought his speakers.
What do other speaker manufacturer's recommend?
  • mpitogo
    mpitogo Posts: 478
    Probably too many customer warranty claims of blown speakers due to clipping with underpowered amplifiers.
    • Living Room Music-2.0 Polk Legend L800 | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Belkin Soundform Connect | iPad Air USB to DAC
    • Media Room Ht-7.2.6/13.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x4], height LSiM703 [x6], HSU VTF-15H MK2 Dual | Marantz AV8805A | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Sony UBP-X800 | AppleTV 4K | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.0 Ascend Acoustics Sierra LX, DSW microPRO3000 | Rotel RA-1570 | Marantz HD-CD1
    • Daughter's Bedroom 1-2.0 TBD Martin Logan Forte | Roku TV
    • Guest Room 2-2.0 Klipsch RP-600M | Martin Logan Forte
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Topping DX7s | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
    tonyb Posts: 32,906
    Most will tell you a range, a safe operating range for their speakers. Usually represented in "recommended watts". They will stay away from recommending specific power requirements as that lends itself to liability.
    It's always up to you, the end user to do your due diligence, educate yourself about power and audio in general.
