SDA 3.1tl resto-mod
Very nice!Home Theater/2 Channel:
dhsspeakerservice.com/ -
Looking good
Stunning!!2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Awesome.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
I hate to say it, but looks splotchy.Political Correctness'.........defined
President of Club Polk -
It's hard to tell when you are being literal or facetious.
I think any patchiness is just reflection showing up on the finish. -
Pleasure in the job puts perfection in the work.
Aristotle
Making progress on my outriggers. Used 1.5" x .5" square bar and a 1/4-20 tap for the spikes.
Literal, cherry tends to splotch.I think any patchiness is just reflection showing up on the finish.
Perhaps so.
They look good. For future reference, you can buy aluminum ones already made from 80/20.Political Correctness'.........defined
Well, I'm pretty happy with the result. Not perfect but they are much better than when I bought them. The sound seems a bit off-center so I still need to do a bit of trouble shooting when I get some time.
Those came out great
Congrats2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I agree as they look awesome to me2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Very Nice!
The finish reminds me of the Pioneer Birch for the Usher speakers2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
gwg_97,
Your speakers look terrific. The cabinets really look modern."Sometimes you have to look to the past to understand where you are going in the future"
Harry / Marietta GA -
Beautiful Job!Home Theater/2 Channel:
They sure look purdy
Thanks guys! The 2000 grit abralon hand rubbing over gloss creates a really nice finish but it's a lot of work.
You've done a very nice job of renovating these old classics, I think they look great.
Hope you get your center imaging worked out, I had a bad connection between a jumper wire on the binding posts at one time on a pair of SDA's, they acted much the same. -
Mike Reeter wrote: »You've done a very nice job of renovating these old classics, I think they look great.
Thanks and thanks for the heads up regarding the jumper wire. I'll check it out. -
Good job, the finish looks a lot better! That is the first SDA transformation from end caps and cloth sides to an all wood veneer cabinet I've seen that looks right, congratsPolitical Correctness'.........defined
Very, very nice. Great job they look awesome!
GOOD SHOW OLD CHAP
EXCELLENT PIECE OF KIT THERE -
Nice work! Thank you for sharing.
Where the hell was I during all this??
Love em!!! Nice Job!!! -
I think that an updated grill cover would look great if it just covered the outline of the drivers and left some of the new cherry wood exposed above and below that dimensional. It would showcase the mirror imaging design of that particular SDA too.
Nice job, could be the best new thought on SDA aesthetics that I have seen come along!
It does resemble the direction that Tekton has gone with its baffle designs.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Cleanest looking SDAs I've seen. Nice work.Don't take experimental gene therapies from known eugenicists.
Thanks everyone! I thought I would post a photo of the matching center channel on the 1 year anniversary of the start of this thread. Its a monitor 5Jr/Monitor 10 hybrid based on the design developed by westmassguy (thanks again!). It works very well with the SDAs.
Looks familiar Beautiful Veneer Work.Home Theater/2 Channel:
