Wiring Schematics Stickies?
msg
Hey guys,
curious now after reading Ivan's request for schematics and note about the links/attachments being dead. I was looking into this trying to find a way to access the info, but haven't been able yet. Seems like a right-click > save should get there, but I'm getting "Forbidden" when it goes to download the .pdf.
I imagine others are aware of this issue - is there a work around?
Chrome says you "may need to log in", which, if these are hosted on an old version of the website, probably isn't possible.
Tried pulling up through archive.org Wayback Machine, but it apparently didn't crawl attachments, unfortunately.
Sure did get a smile seeing a snapshot of the forum as it looked when I joined
https://web.archive.org/web/20130601154231/http://www.polkaudio.com/forums/showthread.php?38755-POLK-AUDIO-Speaker-Wiring-Schematics-amp-More-ALL-MODELS-except-SDA
I just tried three at random on an Android phone and they all worked.
Really? From which links?
You're able to actually view the pdf file?I disabled signatures. -
I can see it
It's the xover for the 11t2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I tried a couple Monitors, this ^, one from the SDA thread. Stock Chrome browser/PDF viewer. I could download and see all of them.
CNN you pull the RT55i one? I couldn't pull it.I disabled signatures.
Me neither.
for one if the link works it shouldn't matter whether it's a phone or pc -
Never hurts to do the usual troubleshooting. Make sure everything is up-to-date, check Settings, clear cache, and reboot.
